spastic speedometer
Old Nov 25, 2007 | 04:30 PM
Mr. G's Avatar
Mr. G
spastic speedometer
Howdy all, I recently bought a 74 F250 390/C6 and the speedometer didn't work. I found out that the cable had been laying on the exhuast and had burt through. So I changed the cable. The speedometer works but the needle jumps up and down while excelerating or just cruzing. I pulled it out of the tranny and it seems to turn smoothly as far as I can tell but is this normal for thes trucks?
Old Nov 25, 2007 | 04:48 PM
Mil1ion's Avatar
Mil1ion
Maybe be the speedo head is dirty and has old hard grease on it ?
Take it out an lube it up.
Old Nov 25, 2007 | 04:49 PM
Mr. G's Avatar
Mr. G
Good idea. I will try it today.
Old Nov 27, 2007 | 06:52 PM
Mr. G's Avatar
Mr. G
Well I took it back apart and oiled the speedo, but the thing is, it seems to move very smoothly. So I got to looking at the cable and where it coneects to the speedo and the cable looks like it is too small. It is hard to measure but the cable is about 3/32 and where it plugs in it is a hair over 1/8 so I'm thinking that it is skipping. I mean it acts like it is skipping. I guess all I can do is maybe buy another cable from a higher end parts store or shim it somehow. Anyone ever run into this?
Old Nov 27, 2007 | 07:20 PM
fasthauler's Avatar
fasthauler
Cables are usually universal in size, but you never know what can happen. The problem you are having is usually caused by the cable sticking and then releasing. this is usually caused by lack of lubrication or dried up grease as Dennis suggested. Occasionally the cable can be in a bind and this can cause the sticking and releasing. I would check the entire length of the cable for any binding. Also pull the cable completely out of it sheath and make sure its not fraying somewhere. The cable should slide freely in and out of the sheathing, if not then you definitely have a bind on the cable.
Old Nov 28, 2007 | 07:01 PM
rusty7983's Avatar
rusty7983
my spedometer only works under 30 mph. and its off. i need to use my wifes gps and get it right. what do y'all think is wrong with my speedo? never seen one partially work.
Old Nov 28, 2007 | 07:24 PM
boggerted's Avatar
boggerted
Maybe your gear inside the trans (or rear, i forget on these trucks), is damaged?
Old Nov 30, 2007 | 07:44 PM
rusty7983's Avatar
rusty7983
i must check, the rear seal is shot i worked to pull it today. will finish later this weekend.
50trucking
Sep 23, 2014 03:13 PM
65fstback
19
Nov 2, 2013 05:05 AM
limeyellowfellow
May 15, 2012 08:26 AM
rashanny
24
Mar 31, 2011 11:14 PM
rockyrunner99
Jan 20, 2009 07:23 AM
