Speedometer problems
Old May 13, 2012 | 04:03 PM
limeyellowfellow's Avatar
limeyellowfellow
I have a 71 F100 that had the column shift tranny swapped for a 4 on the floor. The speedometer didn't work when I got the truck. When I pulled the speedo cable the gear was a little stripped. I ordered a new gear and presto, It still does not work. When I manually twist the drive shaft inside the cable the speedometer moves so the cable is good. How do I figure out what drive gear I need for an unknown transmission? I am new to fixing basket cases that are not stock so please be gentle.
Old May 14, 2012 | 11:13 AM
kenny nunez's Avatar
kenny nunez
speedometer
Limey, What side of the transmisson does the cable go into?
Kenny Nunez
Old May 14, 2012 | 12:46 PM
limeyellowfellow
It goes in the driver's side of the transmission.
Old May 15, 2012 | 08:26 AM
kenny nunez
speedometer
Lime, Is the transmisson a "toploader" Ford or an earlier style "sideloader",or is it a heavy duty truck transmisson. look inside where the cable goes in and count the teeth on the drive gear. This may help to identify what you have. Also,try to determine what 1st gear ratio the transmisson is. Raise the rear wheels and chalk mark the driveshaft and tail shaft housing , remove the coil wire and have someone turn the engine by hand and count the turns to make the driveshaft make 1 turn. The "number dummy" on this site is a great help on these type of problems. Kenny Nunez
okie trucker
22
Feb 1, 2019 09:04 AM
fongguaysurre
May 12, 2017 08:56 PM
catneck
Jun 4, 2016 05:21 PM
Shiveron
Sep 30, 2014 06:44 AM
TBTRUCK
Sep 30, 2012 12:55 PM
