speedometer issue om 91 f150
Old Jan 7, 2009 | 04:29 PM
rockyrunner99's Avatar
rockyrunner99
I live in Michgan and the past 2 winters the speedometer quits working in the winter, and starts again in the spring! There is a cable and wires coming out of the back of the trans, I am guessing the cable drives the odometer and the speedometer is electrical? I have checked both, the electrical connector and the cable, they both seem fine. has anyone else had this issue?
Old Jan 7, 2009 | 10:15 PM
jroehl's Avatar
jroehl
Both your speedo and odo should be cable-driven (same one) in that vintage. But, to know what the wire is, we would need to know more about your truck--engine, tranny, 4x2 or 4x4, etc.
Jason
Old Jan 8, 2009 | 12:10 AM
Prozon's Avatar
Prozon
Maybe there's a chance you have water in there thats freezing your speedo gear in place? :O
Just a random thought. Haha.
Old Jan 8, 2009 | 12:27 PM
rockyrunner99
well it is a 4x2, has the 300 6, and has the 4 speed auto (3+overdrive). The funny thing is the speedometer will jump around, from maxed out back to somewhere near the speed I am driving, to maxed out. yet, the odometer still works. That is one of the reasons I thought they worked differently.
Old Jan 8, 2009 | 04:21 PM
EPNCSU2006's Avatar
EPNCSU2006
It sounds like the cable is sticking, winding up and then popping free. When it pops free, the speedometer end unwinds faster than the steady speed on the transmission side causing the speedometer needle to surge to much higher speeds than you're actually traveling.
Old Jan 8, 2009 | 05:58 PM
rockyrunner99
yeah, I understand how that would happen. But, my speedometer spends most of the time maxed out, or at least above the speed I am actually going. I will pay closer attention to it tomorrow. If that is what is happening, would a shot of wd-40 help? what else could I do? thanks
Old Jan 8, 2009 | 09:02 PM
fmr9's Avatar
fmr9
This issue was fairly common in the 50's and 60's vintage cars.
The solution then was to pull the cable out of the sheath, wipe it clean as possible, then grease it generously , and reinstall it.
Check the cable for damage while you have it out.
Good luck Frank
Old Jan 8, 2009 | 09:11 PM
EPNCSU2006's Avatar
EPNCSU2006
Is this only in the winter?
Old Jan 9, 2009 | 10:16 AM
rockyrunner99
yes this only does it in the winter. my guess is moisture gets in there and freezes. It will be fine by March or April, if I don't fix it before then. I just think it is funny that when I am going 5mph in a parking lot, the speedometer is maxed out! Also the odometer still works and is accurate.
Old Jan 9, 2009 | 05:04 PM
EPNCSU2006's Avatar
EPNCSU2006
It sounds like something might be sticking in the speedometer head since the odometer continues to work, but I don't know why it would be a winter-only problem.
Old Jan 20, 2009 | 07:23 AM
broncobasher's Avatar
broncobasher
Similar problem
My speedo has periodically bounced at speed. This morning, it was bouncing worse than normal and then began buzzing loudly and wrapped back around to the peg. It would return to 0 when stopped and then pick back up to the buzzing after about 35mph. It also hung around 5-10 a couple of times when stopped and a quick whack to the dash made it drop back to zero. The ODO seems to be working fine. Has anyone sucessfully repaired this problem? Can you disassemble the speedo head independantly from the ODO? Would lubing the speedo solve the problem? I plan on lubing the cable, but wanted to know if the speedo needs work while I have it out.
90 f150 4x4 AOD
Thanks,
BroncoBasher
maverick600
Oct 29, 2016 08:10 PM
bradphx
Oct 12, 2016 04:07 PM
52 F1 Stocker
Oct 21, 2015 08:20 AM
JacobRM
19
Jun 3, 2014 06:35 PM
rcbisset
Sep 11, 2002 12:29 PM
