Starting problem
Old Nov 25, 2007 | 02:44 PM
00diesel's Avatar
00diesel
Question Starting problem
The past few days my 00 F250 hasnt been starting like it used to. I have to crank on it several times before it does start. And while im trying to start it, it has alot of white smoke coming out of the exhaust. Once it starts its kinda rough for a few seconds then its back to running like it always does. I'm hoping someone out there can give me some answers bc i have no idea. Thanx in advance everyone.
Old Nov 25, 2007 | 02:47 PM
fxstbchopper's Avatar
fxstbchopper
Sounds like the Glow plug relay has gone bad or is going bad.
Edit: And welcome to the FTE!!!!!
Old Nov 25, 2007 | 02:51 PM
00diesel's Avatar
00diesel
Would that cause it to start hard when its 30 degrees out? Kinda new to this just curious
Old Nov 25, 2007 | 02:53 PM
ron's power stroke's Avatar
ron's power stroke
welcome to FTE happy reading
https://www.ford-trucks.com/forums/4...ke-thread.html
Old Nov 25, 2007 | 02:58 PM
fxstbchopper
Yes and Ron has you covered read the thread he has linked.
Old Nov 25, 2007 | 04:12 PM
00diesel's Avatar
00diesel
thanks im gonna try the gpr tomorrow when i get of work and ill find out mon nite before i goto work if its the prob. will the GPR-109 work on my truck alright?
Old Nov 25, 2007 | 04:21 PM
ron's power stroke
yes the 109 works..you can uprade if you want.and if you can get this near home..sounds like you needed it yesterday...but it is a better set up..
http://guzzle.rbmicro.com/s_gpr.html
Old Nov 25, 2007 | 05:13 PM
Orezona's Avatar
Orezona
I installed that relay before my Pheasant trip to ND this fall. It works great. Not that my 109 didn't, I just liked the idea of a heavier duty relay.
And every step was from Guzzle's site.
Old Nov 25, 2007 | 05:15 PM
00diesel's Avatar
00diesel
ill prolly get the 109 to get me goin and get the other ordered so ill have it to put on
Old Nov 26, 2007 | 06:08 PM
00diesel's Avatar
00diesel
Well the relay seems to have been the problem. Thanx for everyones help. I'm sure glad i found this site everyone is a big help and ill def continue using and recomending it.
Old Nov 26, 2007 | 06:23 PM
ron's power stroke
glad we could help....stick around for a while..we can help you spend the $$ you saved ....on some mod's for you truck
Old Nov 26, 2007 | 07:45 PM
fxstbchopper
Glad to hear you got it taken care of.
And yes you have to watch everyone around here real close they like spending your money for you!!!!
That's not all bad either your truck will thank you to and you will not be able too remove the grin.
np435
New Member Introductions
Jan 17, 2007 01:53 PM
sw99
Modular V8 (4.6L, 5.4L)
Aug 8, 2006 08:43 PM
kdogdan
May 2, 2006 01:52 PM
00Lariatman
Jan 14, 2005 04:56 PM
Bristrew
Dec 27, 2004 09:24 AM
