Charging system
Old Jan 14, 2005 | 04:01 PM
00Lariatman's Avatar
00Lariatman
Charging system
I noticed that it takes a few minutes after startup for my charging system to kick in. Is this normal? I have a friend with an 03 that says his does the same thing. This morning when I started it I turned the lights and wipers on and the wipers moved real slow. Then after I drove about a block the lights go poof and get brighter all of a sudden. It's like it takes a minute or two for the voltage regulator to kick in and start working.
Old Jan 14, 2005 | 04:06 PM
kmill35's Avatar
kmill35
The charging system is working normally as soon as the truck is started. It is just the cycling of the glow plugs after start up to reduce smoke that causes the low reading. They pull quite a bit of power.Its qite normal for the strokes to do this.
Old Jan 14, 2005 | 04:35 PM
Robbgt's Avatar
Robbgt
yep, thats just your glow plugs running, they draw a LOT of power, once they kick off the voltage comes back.... Normal.... you might want to wait till the voltage comes back up to turn the lights on and take off, this keeps the extra load off the electrical system, just my opinion though...
Old Jan 14, 2005 | 04:56 PM
00Lariatman
Thanks guys thats good to know that I dont have an alternator going bad or something.
MPohl
1997 - 2003 F150
Jun 15, 2011 09:48 PM
BriansPence
Feb 15, 2010 06:25 AM
77 bird
Jan 31, 2008 10:02 PM
