Keyless entry....
Old Nov 20, 2007 | 01:06 PM
  #31
Neal 97 250's Avatar
Neal 97 250
All I see is the grey plug to the right and the black small plug at the top of the pic. Am I in the right area?
Old Nov 20, 2007 | 01:10 PM
  #32
ono_55's Avatar
ono_55
Neal to get a good look at it you need to pull the panel off that has the covey hole, there will be a 3"X4" module there if it has one.
Old Nov 20, 2007 | 01:26 PM
  #33
Neal 97 250
If not I assume it will a capped off plug?
Old Nov 20, 2007 | 01:39 PM
  #34
ono_55's Avatar
ono_55
I would think so, but you never know
Old Nov 20, 2007 | 01:40 PM
  #35
ono_55's Avatar
ono_55
Neal i have some stuff to take care of i'll get back on tonight with some part numbers and try to post some pic. Have a good one.
Jim
Old Nov 20, 2007 | 01:41 PM
  #36
Neal 97 250
Thanx bro. When I get time I may take off that panel and investigate. Have a good evening.
Old Nov 20, 2007 | 01:48 PM
  #37
tjbeggs's Avatar
tjbeggs
Neal look further up inside the dash. closer to the lower lip.
Old Nov 20, 2007 | 01:58 PM
  #38
superduty4x4's Avatar
superduty4x4
Neal, pull the black dash bezel off. On the right side of where the bezel was there is a good sized hole in the dash (near the center) and through that hole you can see the remote keyless box if you have one. I just had mine apart doing a gauge cluster swap, and noticed it because it said something about remote keyless transmitter or something to that effect on it.
Old Nov 20, 2007 | 02:03 PM
  #39
1997F-350's Avatar
1997F-350
neal you dont have it it looks like.
i have had these pics in my wbshots for a while. the grey plug is right above the go pedal. the brain is directly behind the cubby hole on the dash has fcc id #'s on it and stuff. to program more than one is easy. i even have the written instructions.
cody
any style #2 fob from ford will work even if it says ranger or explorer. buy a couple used they are usually less than 5 bucks.
to program goes something like this
turn on key
use screwdriver to jump grey plug locvks will cycle hit a button on fob
locks cycle again turn off key and lock cycle again and try fob.
if you wanna do more than one hit the button on another fob before turning off key and after locks cycled from previous fob.
a picture to help......took this a while ago i will scan the directions later and post them..
remember style #2 fob
the .................................click--->>>>>>brain
Old Nov 20, 2007 | 03:30 PM
  #40
Neal 97 250
Yup I definately don't have the "brain" that is in your webshots. That area is completely empty. Do you think it is possible to get the brain from a junkyard? Or are the wires missing also. I don't see any capped or spare plugs either.
Old Nov 28, 2007 | 11:05 AM
  #41
erl_berner's Avatar
erl_berner
Not much, the instructions come with the keyfob's. Let me know if they don't, I'll forward you a copy of mine. I just got a second fob off of ebay.
cassenbl
Apr 7, 2015 12:33 PM
fordguy2236
1997 - 2003 F150
Jul 13, 2013 09:49 PM
95PSDieselP
Apr 8, 2012 12:02 PM
ogbobbyjohnson
1997 - 2003 F150
Feb 11, 2012 09:47 PM
loner
Electrical Systems/Wiring
Jun 11, 2002 02:43 PM
