Autoenginuity keyless entry
Old Dec 21, 2012 | 02:53 PM
cassenbl's Avatar
cassenbl
Does anybody know if AE will retrieve the factory code for the keyless entry. I have my code written down so I do not have a problem but was just wondering if AE would retrieve that data.
Old Dec 21, 2012 | 05:14 PM
tdappleman's Avatar
tdappleman
Not sure on AE but I know my Snap On Solus Ultra scan tool will not pull it.
Old Dec 21, 2012 | 07:20 PM
projectSHO89's Avatar
projectSHO89
That code is printed on a label on the module that controls the RKE function. It's easy to acquire.
Old Dec 21, 2012 | 08:10 PM
mtnsammy's Avatar
mtnsammy
AE has no programming abilities. It can reset tire sizes and minor stuff but not reset key or program a new set of keys.
Old Dec 21, 2012 | 08:42 PM
projectSHO89
Keyless entry has nothing to do with those functions.
Old Dec 21, 2012 | 08:54 PM
cassenbl's Avatar
cassenbl
Thanks. Was just curious because of forums I have seen posted of people having trouble findind their code.
Old Dec 22, 2012 | 08:58 AM
double ott ex's Avatar
double ott ex
I have ae and I can assure you it can read but not reprogram the keyless entry code. it can also program keys and fobs to the system.
DOE
Old Dec 22, 2012 | 12:15 PM
tdappleman's Avatar
tdappleman
Good to know - my Solus says it will but it doesn't come up as an option in the menus.
Old Dec 23, 2012 | 03:27 PM
cassenbl's Avatar
cassenbl
DOE,
Where do you find it in AE?
Old Dec 23, 2012 | 03:53 PM
double ott ex
Originally Posted by cassenbl
DOE,
I will have to fire up the software to check. I can do that later today when I get back home.
DOE
Old Dec 23, 2012 | 08:03 PM
fsmt's Avatar
fsmt
will snap-on show GEM data display
if you can get GEM data up on the screen it is a PID. Not a function.
Old Dec 24, 2012 | 02:15 AM
Nsaan's Avatar
Nsaan
DOE,
It depends on the year of the vehicle. Some vehicles have a Vehicle Security Module and the later years have a GEM, my 2000 I found the code in the VSM, you have to connect directly to the individual modules with the AE, once connected you will see the options on the drop down screen.
If the GEM is not programmed or damaged it will not work. My Brother in Law has a 2002 X that has a salvage/restored title, the door keypad does not work to unlock the vehicle, but it will lock it. When I connected to the GEM it said code not programmed, but gave me an option to enable it, but not to program the code. So it never worked. They think the GEM on that truck is damaged but they are not sure. It does all kinds of weird things with the inside lights sometimes, there are times they come out and the batteries are dead. Glad it's not mine.
Old Feb 16, 2014 | 10:51 PM
jshalala's Avatar
jshalala
Did you guys ever figure out how to get the key pad code with AE?
I plugged mine in today running the newest version of AE but did not see that option. Where would I look?
Old Apr 7, 2015 | 12:33 PM
01 EX PSD's Avatar
01 EX PSD
I have v13. Not having the keyless entry code on my 01 X was one of the reasons I got the program. I connected to the GEM, click on special function, press the drop down menu, select factory keyless entry code, and click initiate.
willtim1234
2009 - 2014 F150
May 10, 2019 09:41 PM
RainDesert
Nov 7, 2016 12:10 PM
unique
Jul 31, 2006 12:53 AM
otismojo
Apr 29, 2002 03:03 PM
