i believe if u look at the layout for all ur fuseboxes, u will see a fuse / relay assigned for keyless entry. check the fusebox and see if there is a fuse / relay in there for ur keyless entry thing.
i may be wrong. there may be no relays for tat sort of thing on the fusebox, but i'm kinda certain there is a fuse for it.
if u dont have ur owner's manual, u might wan to do a google search for the fusebox layout.
bud, i tink he meant keyless entry as the key unlocking / locking function. tat kind of setup. i dont tink he meant on the door thing.
however i could be wrong too. lol.
tat setup above tat i mentioned exists if ur trying to get another keyless remote for the car. i believe some cars may not have the option for keyless remote or they may be missing the corresponding fuse on the fusebox. plug in a new fuse, and u'll be able to use a keyless remote on it.
scott, jus to be on the safe side and tat i dont give the wrong advice, were u talking about the keyless keypad or the keyless remote?
