What time is it?
Old Nov 19, 2007 | 09:00 PM
DCP's Avatar
DCP
Smile What time is it?
I'm slowly putting life back into an '82 F350 SRW 4x4. The previous ower wasn't very nice to it but, my questions are. One, is there a company that sells new in-dash Sparkomatic type clocks for the early 80's Fords? And second, is there a company that makes replacement dash pads for these trucks? I'd rather replace the whole dash pad rather than covering it up with a slip-on cover. I've been through many salvage yards trying to find these parts but, the junk yard parts aren't much better than mine. Please let me/us know if there is such a company, thanks.
Old Nov 19, 2007 | 10:35 PM
93F150/302's Avatar
93F150/302
For the dash pad try LMC truck. I don't know about the clock since I haven't seen it in the catalog. Would look but I gotta get going
Old Nov 19, 2007 | 11:47 PM
DCP's Avatar
DCP
In LMC you can buy almost any dash board parts, besides the pad. And the only clocks they sell are the one you hang on a wall. Its going to suck when I get my truck done and still have a dash pad that looks like hell.
Old Nov 20, 2007 | 05:40 AM
srercrcr's Avatar
srercrcr
Nice pads come up on ebay occasionally, might run as much as $100 including shipping. That's how I got my blue one, but it takes checking your customized search every day...alot of patience....not something most people have much of nowadays.
Old Nov 20, 2007 | 07:42 AM
GlennFordx4's Avatar
GlennFordx4
I don't know what you have against' the dash board covers I used one from LMC and the only way you could tell it was a cover is when you took it off and you could see the old speaker mesh,they really have a nice fit.
If you look in my gallery at Barney you can see my cover.
Old Nov 20, 2007 | 09:40 AM
ken's 80's Avatar
ken's 80
Like Glenn, I was pleased with the dash and both door panel covers. All three fit nicely and installed easily with a little TLC.
My interior can be seen in my gallery also.
Good luck.
Ken
Old Nov 20, 2007 | 12:20 PM
LARIAT 85's Avatar
LARIAT 85
Hi DCP.
You will NOT find a Ford dash pad for 1980 - 1986 Ford trucks because no vendor that I know of makes them, at least, not yet. And I have been checking them ALL for 3 years now. The only way you are going to find an original Ford dash pad is to keep searching on ebay, and you might get lucky. But then chances are you are going to have to dye the pad to match your truck. It's been a while since I have seen a good one that doesn't have the speaker hole busted out of it. And if you do find one, it is going to cost you.
The Ford clocks are another one of those itens that you are not going to find, because no vendor that I know of makes them either. Again, I have been searching for 3 years now. Again, ebay is going to be the only source.
Old Nov 23, 2007 | 03:07 PM
ken's 80's Avatar
ken's 80
I MUST clarify my response. I did not purchase a "dash pad" I bought a "cover" that is glued onto the existing dash pad.
If you are looking for an original padded cover, I wish you good luck.
Old Nov 24, 2007 | 01:47 PM
Piffery1's Avatar
Piffery1
If you buy an original Ford clock on ebay or at a junkyard make sure you get the clock wiring harness/connectors with it. That way it's plug/play. Without the original clock harness you have make up one. Clocks with the harness rarely show up on ebay but I've seen several harnesses in junk vehicles where the clocks had already been removed.
Old Nov 25, 2007 | 12:00 AM
86bigred's Avatar
86bigred
are there not companys out there that can recover your old dash pad,i remember reading about it in a car mag.i believe it will cost ya though.i think a cover is your best bet.
Old Nov 25, 2007 | 12:49 AM
bedmondo's Avatar
bedmondo
wow i guess i got really lucky then! i picked up a PERFECT dash pad for my truck at the junkyard...in my interior color!! I walked up to a completely trashed ford at the junkyard, and walked out of there with a beautiful dash pad...and the best part was that it was only 20 bux!
Old Nov 25, 2007 | 07:31 AM
ri_truck_guy's Avatar
ri_truck_guy
I've got a pretty nice spare dash pad sitting in the garage...it needs some fiberglass repair to a couple of the u-nut mounting points where the dash bezel screws to the pad, but that's a really easy fix. Beyond that the only defect is a 1/4" crack between two of holes on the speaker grill that you really have to look for to notice. Right now it's gray, but SEM makes spray dye in all the factory colors....the stuff works so well you have to try hard to mess it up. Let me know if you think this might help.
78f250_rls
16
Nov 11, 2024 12:57 PM
Zach Hill
32
Dec 9, 2014 12:51 PM
Brettboat
Sep 9, 2013 03:55 AM
fordinmudd
Appearance & Dress-Up
Apr 14, 2008 10:54 PM
1979FordF250
Aug 7, 2006 08:53 AM
