Blower motor making weird noises
Old Nov 24, 2007 | 07:20 PM
boggerted's Avatar
boggerted
My 84 f250 has been making weird noises whenever I turn on my heater. Its a very loud squeaking/moaning noise that usually happens when you first turn the heat on, but it goes away eventually on its own or if I punch the pass. side fender it will stop. Why does it do that? Is that normal?
Old Nov 24, 2007 | 07:25 PM
Franklin2's Avatar
Franklin2
Either junk in the duct, or the bushings are dry in the blower motor.
Old Nov 24, 2007 | 08:15 PM
powerstrokinit's Avatar
powerstrokinit
dismount the blower motor and check the insides for build-up, if it is free of deposits try applying recommended lubricant.
Old Nov 24, 2007 | 10:20 PM
Harte3's Avatar
Harte3
On an '84 it has probably seen better days. Might be best to swap out for a new one.
Old Nov 25, 2007 | 06:37 AM
boggerted's Avatar
boggerted
When I got it I took the blower out because it didnt work at all, but the housing was pretty clean, but It probably needs some lube. Where do you put the lube and what kind is the best?
Old Nov 25, 2007 | 01:41 PM
Franklin2's Avatar
Franklin2
You may have to take it apart to lube the bushings. Should last for another 20 years if you do it though.
lil-red-f150
Jan 5, 2015 09:45 PM
lemasters f100
Sep 27, 2013 09:21 AM
lawlor
Aug 12, 2007 01:06 AM
jnye6625
Mar 14, 2007 10:08 AM
Probable Cause
Jan 5, 2006 05:11 PM
