92-97 dash pad
Old Sep 8, 2013 | 04:31 PM
Brettboat's Avatar
Brettboat
92-97 dash pad
I got a crack in my 97 F250s dash pad. Interior is that royal blue color, code "6V" from what I recall. Anyways, I can't really find that pad that runs from the radio to the passengers door in that blue color. But I found these covers on Jeffs Bronco Grave Yard.
Wanted to know if I should get the light blue or dark blue for a code "V" interior.
1992-97 Dash pad cover-Dark Blue
1992-97 Dash pad cover-Light Blue
Doesn't help they don't really have pictures, let alone info on what trim code it goes with.
Old Sep 8, 2013 | 06:39 PM
Diesel_Brad's Avatar
Diesel_Brad
Neither. Keep an eye on ebay, craigs list and the like. Or go to a junk yard for a blue dash pad.
Those overlays are junk
Old Sep 8, 2013 | 06:57 PM
Brettboat's Avatar
Brettboat
Just picked up one on ebay for $100 out of a 96 truck so I'm pretty sure the color will be right.
Now I need to figure out how to remove the old one and put this one I bought on...
Old Sep 8, 2013 | 07:13 PM
Diesel_Brad
A buch of nuts from the backside. Once you get the new one you will see where they are
Old Sep 8, 2013 | 07:31 PM
Brettboat's Avatar
Brettboat
Take the radio and glove box out to get to them I'm guessing?
Old Sep 8, 2013 | 07:46 PM
f1504x4driver's Avatar
f1504x4driver
Proud Pirate
Yes, take out the glove box and the radio to get to them. I quarter inch drive ratchet is your friend here. There are seven nuts if I remember correctly. The four around the radio are the biggest pain. I have the blue interior as well and the 92-94 are a lighter shade. I have had a hard time finding the darker one for my 95 on ebay or at the jy.
Old Sep 8, 2013 | 08:27 PM
Brettboat's Avatar
Brettboat
Yea, I guess I got lucky. I found 5 or 6 pads from like 92 and 93 trucks, but I found that one from a 96 and it looked darker in pictures than all the others so I'm gonna take a guess it's the right color... Hope so atleast you know? haha.
I have a really small snapon ratchet at work and an even smaller matco offset screwdriver with a 1/4 drive adapter. One of those will work I guess... I know how to get the radios out of these trucks (aftermarket head unit, super easy)... But I've never taken the glove box out. I'm always afraid to work on the interiors of these trucks because the plastic is so crappy.
http://www.ebay.com/itm/350871018261...S:3160&vxp=mtr
Old Sep 8, 2013 | 11:37 PM
SideWinder4.9l's Avatar
SideWinder4.9l
Ford F150 F250 F350 Bronco 92 93 94 95 96 Dash Pad Blue | eBay
Just open the glove box, and press the 2 tabs at the bottom.
It'll pop up a bit, then slide it up and straight out. Simple as that.
Old Sep 9, 2013 | 03:55 AM
EzPc's Avatar
EzPc
Or if you can get the color in a spray can you could try the repair route. A fella over at Fullsizebronco.com did his and I think it came out great:
Cracked Dashboard Fix - FSB Forums
At least you can give it a try, if it does not work you can always buy the replacement...
sleddog60
25
Oct 6, 2016 08:38 PM
creedua
Mar 6, 2015 06:20 PM
Rick_Fury
Nov 8, 2010 12:40 AM
Country705
Jun 24, 2006 04:46 PM
Keigeman
13
Jul 3, 2003 09:48 AM
