computer crashed
Old Nov 18, 2007 | 07:58 AM
wizzard351's Avatar
wizzard351
computer crashed
was just wondering if this happens is every thing (like pic's)that i had not save to a disc be lost forever? it wont even boot up
Old Nov 18, 2007 | 09:16 AM
jake00's Avatar
jake00
you might just be missing some files needed to boot up, but the drive is still fine
but if the hard drive is making very strange mechanical noises, then yes, everythig may be lost
Old Nov 18, 2007 | 10:41 AM
exiled's Avatar
exiled
"Lost" more than likely not. It might be a challenge in getting them back.
You say that the box wont boot. What do you mean? Does the machine not post, or get any power at all? Not booting describes alot of different things. If the machine posts but windows doesnt open you should get some kind of message or blue screen of death, maybe even black but we would know that the bio is getting things going and that the psu is working. If there is no post then we could at the bio and if no power we'd want to look at the psu. Early dyno of the psu is of course making sure the plug is plugged into the box and socket good, then if the socket has power to it. If all this is good then checking the psu itself is rather easy in that all you really have to do is install a new one.
Theres ways of pulling info off a HD it just depends on how much its worth to you. I'm not just talking money wise but time wise also.
Old Nov 18, 2007 | 11:27 AM
modar's Avatar
modar
I'm the worst at backing up my docs an pics. one day my hard drives will go belly up and all my stuff will be lost. I should do a back up right now. I send my pics to the external drive as back up but, I really need to burn them to disk too.
Old Nov 18, 2007 | 12:15 PM
Kwikkordead's Avatar
Kwikkordead
I have duplicates of all my pictures on two separate hard drives for backup purposes.
I recently lost my main computer's CPU. The thing wouldn't even POST but make a high/low/high/low beeping noise that ended up being a fried CPU.
Simple matter of removing the hard drives from the computer and installing them in a different computer and all is back.
Now I just need to get the main computer replaced so I can actually edit those photos.
500mhz P3 with a non-3d video card is just a tad slow for that.
Old Nov 18, 2007 | 02:38 PM
wizzard351's Avatar
wizzard351
ya all it'll do is turn on and run a few seconds and shut back off. i did go buy a new one yesterday spose to be top of the line(for 3grand it better be!!) i would at least be able to get my stuff off the old one to put in te new one.
Old Nov 18, 2007 | 05:21 PM
sierraben's Avatar
sierraben
I usually back up some of my pics and other documents by emailing them to myself.
Old Nov 18, 2007 | 05:41 PM
donjamer's Avatar
donjamer
Well seeing as how you spent that much just go buy a USB hard drive enclosure($30.00).. Take the hd out of the crashed one and put it in the enclosure connected to the new pc.. If it reads it back up the stuff..
If it doesn't recognize it then forget about it..
If there is stuff you absolutely need Seagate(As well as others) has a recovery service.. It is not cheap.. I priced it out for a customer and they wanted $1400.00
Old Nov 18, 2007 | 08:46 PM
Mil1ion's Avatar
Mil1ion
That's what I did last year.
The Former C :/drive is now the H:/ drive via USB
Old Nov 18, 2007 | 09:30 PM
exiled's Avatar
exiled
3grand really does'nt mean anything. You can tie alot of that up in say a large flat lcd screen or a blu-ray burner. I hope for that kind of money your at least running 4ghz quad core liquid cooled w/ 3gigs of ram. If your lucky you have 4MB of level2 cache. Your fsb probally in the mid 200mhz. I bet it has dual video cards.
I bet you have 2 HDs in that thing. You could unhook your master HD and install your old one then backup your old HD to the "slave". I hate to say that cause its going to be setup as cable select but yopu should get what I'm saying.
Old Nov 19, 2007 | 11:11 PM
wizzard351's Avatar
wizzard351
im not shure what this things got but the wife picked it out and im tell ya'll its sweet!!! seems tons faster and even with our old monitor the grafics are just awsome!!
ford2go
Jan 5, 2019 10:42 PM
Nitramjr
Apr 1, 2017 05:31 PM
wreckit72
Oct 9, 2007 04:49 PM
bigdaddyII
20
Oct 30, 2006 10:01 PM
ATC Crazy
32
Jan 26, 2006 07:00 PM
