PC not turning on?
Old Oct 26, 2006 | 10:28 AM
bigdaddyII's Avatar
bigdaddyII
PC not turning on?
Good morning everyone. I am having a little of an issue here and am hoping someone may be able to point me in the right direction. My home PC is an old gateway that was running windows 98 when I got it from a friend almost 6 years ago. I have since upgraded it with a bigger hard drive and windows XP and a CD burner. It has operated flawlessly for 2 years like this. Last night I ran a virus scan, spybot, adaware and defraged. This morning I try to turn it on and I get nothing. It is not even trying to turn on. I pulled the cover off to see whats going on in there, and when I push the power button the processor fan turns two turns than stops like it is losing current. Any ideas? I really cant afford a new on right now, trying to get Christmas straight and all that. I am on my laptop now, but I take it to work with me and would like to try to get this issue resolved before I go back to work so that my wife can have a computer when I am at work. Any thoughts, or suggestions are appreciated. Thanks in advance.
Old Oct 26, 2006 | 11:00 AM
rangerxlt02's Avatar
rangerxlt02
Hey BigDaddy,
It sounds like your power supply went kaput. You stated you hit the power button, fan spins a couple times, then stops. Had to swap one out in a computer here. Hit the power button and I'd get a small noise from my speakers, like the PC was powering on, then nothing.
Suggestion:
Yank the power supply (hopefully that old gateway doesn't have a proprietary power supply in that case), go down to your local pc shop or box store (best buy), and see if theirs look like yours. If they have the same shape, you should be good to go within 10 minutes or so.
Good luck to ya.
Old Oct 26, 2006 | 11:08 AM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
sounds like power supply, but I hate just throwing parts at it. It could be a motherboard issue. Blow a few caps or resistors, and you're not gonna see any action from it, either.
Ryan
Old Oct 26, 2006 | 11:28 AM
spikedog's Avatar
spikedog
Power supply is relatively easy to replace, and not too expensive either.
Old Oct 26, 2006 | 11:41 AM
bigdaddyII's Avatar
bigdaddyII
Okay, update. I just tried it again and the sumbeech turned on. Dont know what to think about it. I do know one thing for sure for as long as it is alive it is not going to be turned off again. Thanks for the suggestions though, I figured the same thing. Maybe it will kick around long enough for me to be able to get a new one.
Old Oct 26, 2006 | 11:54 AM
Mil1ion's Avatar
Mil1ion
Some cases have a power block switch on them when the side is removed.
It's just a wee switch. did you try to start it with the case open ?
Old Oct 26, 2006 | 11:57 AM
00BlueOvalRanger's Avatar
00BlueOvalRanger
Bigdaddy.. . . .
Just a thought - - -
Stick your nose near the power supply (in the back of the PC) and sniff.
IF the power supply smells like 'burning rubber', the power supply could be REALLY going bad.
If it smells, shut it down and unplug it before it shorts out. THEN you will be in dire need of another PC.
Power supplies can be acquired for less than $80 at most places like Best Buy or CompUSA, etc.
A friend's power supply went bad and fried the Motherboard along with it.
(New PC time!!!)
IHTH.
Old Oct 26, 2006 | 12:30 PM
Bart99GT's Avatar
Bart99GT
If you have an old hard drive, paper clip and multimeter, you can test power supplies pretty easily. Just connect the power to the old hard drive, then jumper the green wire in the power supply harness that plugs into the motherboard to one of the black ground wires. It should turn the power supply on, then you can check the 3.3, 5 and 12 volt legs on the power supply.
Usually when a system attempts to power on like that, then shuts back down it could either be the system board or power supply. As one of the other guys mentioned, there are a number of voltage regulators on the system board itself, and if the components there start to flake out, it can cause the computer to shut right down as well.
Old Oct 26, 2006 | 02:39 PM
bigdaddyII's Avatar
bigdaddyII
I smelled the power supply and it dosent smell like anything burnt. That was my first thought. It still dosent smell like anything burnt. All in all I have been needing to replace this computer and this was a good wake up call telling me to get prepared to do it.
Old Oct 26, 2006 | 03:49 PM
fordboy_52's Avatar
fordboy_52
its a bad power supply. buy a new one on www.newegg.com
id recommend a 350 watt atx
Matt
Old Oct 26, 2006 | 04:25 PM
FghtinIrshNvrDie
Brands to look at...
FSP
Sparkle
Antec
There's a bunch more, but those are some reliable ones to get you started. They don't cost an arm or leg either.
Ryan
Old Oct 26, 2006 | 06:09 PM
MinnManBroncoFan's Avatar
MinnManBroncoFan
I got a whole box of 300 watt p4 power supplys.
If you need one pm me.
Just pay the shipping.
Old Oct 26, 2006 | 06:54 PM
jake00's Avatar
jake00
posts like the above make FTE great
Old Oct 28, 2006 | 08:13 AM
bigdaddyII's Avatar
bigdaddyII
Yes Jake, great people like Kirk make FTE great. Here is an update on the cowbox, the PS exploded this morning. Sounded like a fire cracker and than it started smoking and stuff. I guess it was its time to go anyway.
Old Oct 28, 2006 | 08:59 AM
FghtinIrshNvrDie
I hope it didn't take out the rest of the components, unless you're wanting to buy a new one. A'course, lots of people on here, myself included, would be happy to build you a new one and have it shipped.
Ryan
