Yes the 99-up truck have the zf-6. no they are not a direct bolt in for our trucks. they are longer. Somebody here has done it but I can't remember who. I think the driveshafts need some work and some other stuff but not really sure.
Also if i remember. You will get a crawl first gear. I think 5 and 6 are same top gear ratio. But then again my memory is shot! What would be nice is if the PSD had the RPM bumpup as you lift the clutch like the dodge.
The 6sp has a low gear, then first gear. Yes the 6sp has a gear that is even deeper. Don't know the ratio but its near unuseable in a PSD from what I remember
Yea, the ZF 6 is almost identical to the zf5 for 1-5, but it has L, which most trannys dont.
However, the truck i rode in with the zf6 was a PSD. He said its helpfull pulling trailers, dont have to use the gass, just let out the clutch.
Just sparking my curiosity. I love gears. More gears you have more options, (more to go wrong too. hah) but, if you want to skip in a manual, you can.
I dont know why you would want an RPM bump up after clutch depress, Thats friggen annoying as shat in a Gasser. Its annoying enough mine doesn't return to idle for 15 seconds half the time.
I understand the purpose of the thing, to speed up the syncro's. but. syncro's suck. Ask any old trucker. haha
In the dodge you just release the clutch and the pcm rpm's the motor for you.
No need to touch throttle until clutch is enguaged. I think it helps most from burning up clutches. Here is a funny part. Most that drive them dont even know it does this.
If you get a chance check it out. Its cool. All it does is burp the throttle.
You can tell when its in netural and you press/depress clutch it burps the throttle. It burps on release of the pedal.
my dads 6 spd low gear is ok, but second could be a bit lower, for taking off moderate loads. we can take off with 23000+ pounds without touching fuel in granny
btw- when we had our farm logged, the loggers all drove superdutys, and said that their skidders all had zf6 trannys, with a plate to block 6th gear. he said they were bullet proof in those things. (notice i said bullett proof an idiot can tear anything up. anything. nothing is idiot proof)
