Sponsored by: Real Truck
E250 Idle Problems
Old Nov 11, 2007 | 02:49 PM
roc900's Avatar
roc900
E250 Idle Problems
Hello,
I have a 2001 E250 and it idles low when started, sometimes stalling. Today I can't get it running. It starts but idles so low it dies out. Any advice would be greatly appreciated. Thank you.
Old Nov 11, 2007 | 03:38 PM
redford's Avatar
redford
FTE Leadership Emeritus
What engine do you have?
Old Nov 11, 2007 | 04:50 PM
roc900's Avatar
roc900
V8 Triton 5.4L
Old Nov 11, 2007 | 05:52 PM
high ho silver's Avatar
high ho silver
IAC. Idle Air Control valve is in need of cleaning probably. Or just replace it if you want.
Old Nov 11, 2007 | 06:11 PM
roc900's Avatar
roc900
thanks ''high ho silver''. Where is the Idle Air Control valve located and is it hard to clean?
Old Nov 11, 2007 | 06:22 PM
high ho silver
Since you have a van, If you can still access the engine from inside the cab like the old ones, it should be pretty easy to remove. Here is what it looks like: http://www.partsamerica.com/ProductD...pe=506&PTSet=A
It should be toward the rear of the engine at the top somewhere. Remove it and clean the inside cavity with a good carb cleaner
econobox
26
Jan 4, 2013 11:51 PM
skotyg
Oct 24, 2012 02:08 PM
cpettymore7777
Mar 26, 2009 09:13 PM
jlev89
Sep 22, 2006 09:44 PM
gearhead351
Mar 25, 2006 12:34 PM
