I have a 2001 E250 and it idles low when started, sometimes stalling. Today I can't get it running. It starts but idles so low it dies out. Any advice would be greatly appreciated. Thank you.
Since you have a van, If you can still access the engine from inside the cab like the old ones, it should be pretty easy to remove. Here is what it looks like: http://www.partsamerica.com/ProductD...pe=506&PTSet=A
It should be toward the rear of the engine at the top somewhere. Remove it and clean the inside cavity with a good carb cleaner
