&%$*#@+$ PSD
Old Nov 16, 2007 | 10:22 AM
  #106
tjbeggs's Avatar
tjbeggs
Roger I don't know what happens when you don't have the damper and run splits but I do know that you can as my truck has been that way for atleast 50k. I have never checked fuel pressure on my truck to see what it is and how if fluctuates but it runs well.
Old Nov 16, 2007 | 10:49 AM
  #107
MADVAN's Avatar
MADVAN
Tim
Will run fine just more noise.
It dampens the double pulse of the injectors. Reason for the higher pressure of the system. Without the damper you gain inj noise letting off throttle and at idle. Its just like crackle/idle knock.
Bill
Old Nov 16, 2007 | 01:40 PM
  #108
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Maybe To Late
BUT I found this in my records:
CALIFORNA TRUCK FUEL PUMP R&R<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o> </o>
Buya 1/2 " drive, impact socket 1-1/4" and tack welded it to a piece of 1-1/4" black pipe, put it in a metal band saw and cut off the socket leaving only enough to grab the banjo bolt, then ground the tack welds off and ended up with a socket short enough to reach in and unscrew the banjo bolt. Using a 3/8 drive swivel head ratchet and a 3/8 to 1/2" drive adaptor, I managed to break the banjo bolt loose, and finally get it out. I loosened the fuel filter canister and slid it towards the fan, replaced all the fuel lines with Ford factory lines, and new crush washers on the banjo bolt, cleaned the screen on the FPR while I was there. To re-assemble I used a plastic tip off a silicone tube, (new here not used) shoved that into one of the holes of the banjo bolt and then a screwdriver into the tip of the tube,(sounds weird but it worked) shoving the banjo bolt into the fuel line assembly and the pump. Best part of all the truck fired right up with no leaks. Hope this info will help someone on their fuel pump replacement.<o></o>
The fuel dampener was not removed separately; I had loosened the fuel lines at the fuel galleys at the rear of the heads and slid the dampener/fuel line assay slightly towards the firewall. This allowed the lift pump to come pretty much straight up and out of the valley. It really went pretty smooth. I used a little light grease to hold the banjo bolt washers in place until I could get the banjo bolt started back in.<o></o>
for what its worth, Im now running no pulse dampener and it runs the same. Without the dampener it is much easier to get to the banjo bolt also.<o></o>
Old Nov 16, 2007 | 07:17 PM
  #109
kawa's Avatar
kawa
CALIFORNA TRUCK FUEL PUMP R&Rfficeffice" /><o>></o>>
<o>> </o>>
Buya 1/2 " drive, impact socket 1-1/4" and tack welded it to a piece of 1-1/4" black pipe, put it in a metal band saw and cut off the socket leaving only enough to grab the banjo bolt, then ground the tack welds off and ended up with a socket short enough to reach in and unscrew the banjo bolt. Using a 3/8 drive swivel head ratchet and a 3/8 to 1/2" drive adaptor, I managed to break the banjo bolt loose, and finally get it out. I loosened the fuel filter canister and slid it towards the fan, replaced all the fuel lines with Ford factory lines, and new crush washers on the banjo bolt, cleaned the screen on the FPR while I was there. To re-assemble I used a plastic tip off a silicone tube, (new here not used) shoved that into one of the holes of the banjo bolt and then a screwdriver into the tip of the tube,(sounds weird but it worked) shoving the banjo bolt into the fuel line assembly and the pump. Best part of all the truck fired right up with no leaks. Hope this info will help someone on their fuel pump replacement.<o>></o>>
The fuel dampener was not removed separately; I had loosened the fuel lines at the fuel galleys at the rear of the heads and slid the dampener/fuel line assay slightly towards the firewall. This allowed the lift pump to come pretty much straight up and out of the valley. It really went pretty smooth. I used a little light grease to hold the banjo bolt washers in place until I could get the banjo bolt started back in.<o>></o>>
for what its worth, Im now running no pulse dampener and it runs the same. Without the dampener it is much easier to get to the banjo bolt also.<o>></o>>
Roentgeep:
Did you actually do this proceedure to your truck or did you find these instructions somewhere??
Going on the assumtion that you did this. Did you then use a banjo bolt and fuel lines from a later model truck that did not have the access port for the dampner disc? The fuel lines on a non-Dampner model would need a shorter bonjo bolt as the 11/2" area for the dampner to screw into would be gone.
Have you noticed any difference in the way the truck runs? Sounds? Anything?
If there is a way to eliminate that Dampner disc W/O doing damage to any part of my engine it's as good as done. It would be nice to have some spec's on that dampner. I was wondering if the dampner that I bought to install between the FPR and the fuel pressure gauge would be sufficent to dampen the "Spikes" if each line coming from the pump to each fuel manufold at the heads? HMmmmmmmmm
Coonhunter hasn't jumped in on this delima yet. Joe, are you OK?
Rog
Old Nov 16, 2007 | 07:34 PM
  #110
kawa's Avatar
kawa
Tim:
Aren't you running single shot injectors? I seem to recall that you have AD Inj. and those are single shot arent they? Mine are AB (Ithink)
Rog
Old Nov 16, 2007 | 08:18 PM
  #111
tjbeggs's Avatar
tjbeggs
Nope AD's are the split shots that come stock in 99.5 to 03 trucks. But I won't be running them for long!!
Old Nov 16, 2007 | 08:20 PM
  #112
MADVAN's Avatar
MADVAN
AB and AD are splits. The Ad has a bigger shot (CC).
My pump (cali) gets replaced tomorrow. Gee what fun.
I will be pulling the turbo. Like the last 4 times.
Bill
Old Nov 16, 2007 | 08:33 PM
  #113
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Red face
Originally Posted by kawa
Roentgeep:
Rog
No mine is not a cali truck, I found them from somewhere and saved in my PC, sorry, not can help more.
Old Nov 16, 2007 | 08:45 PM
  #114
Action4478's Avatar
Action4478
Bill
You need to buy your pumps elsewhere,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Old Nov 16, 2007 | 08:55 PM
  #115
MADVAN's Avatar
MADVAN
Rick
Iam Fedup with this pump crap! I think its a ULSD thing.
This old pump is going in the box and sent back as a new defect.
New pumps only last a year or so. Its BS.
Let the counter deal with it.
Bill
Old Nov 16, 2007 | 09:57 PM
  #116
kawa's Avatar
kawa
Bill:
Where have you been buying your pumps? I bought this new "Carter" pump from NAPA Auto parts. I had no Idea that fuel pumps were such a weak point. I'm really now considering eliminating that Dampner.
Come to think of it Bill, is your truck a Cali truck? If not why are you pulling the turbo? Hmmmmm
Rog
Old Nov 16, 2007 | 10:02 PM
  #117
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
I think because he has a VAN.
Old Nov 16, 2007 | 11:41 PM
  #118
kawa's Avatar
kawa
OH crap, now I understand his anger, I've been told that they are PITA to get to. My God changing a fuel pump once a year would either make you suicidal or homicidal. Dang.
Roger
Old Nov 16, 2007 | 11:54 PM
  #119
kawa's Avatar
kawa
Bill I have never found two listings for the fuel pump when looking it up nor asked about it when I called Ford. I will call them today and see if there are two listings.
Edit- Just looked at Rock Auto and Powerstrokeshop.com and they both only have one listing for the pump. Rock auto also now has an airtex and bosch brand pumps with the carter. must be they decided to get into the game as well. which is news to me.
Kawa, i couldn't find any pics with the damper removed.
TJ:
My pump box is labled as AIRTEX but the pump is embossed "Carter"
Old Nov 16, 2007 | 11:58 PM
  #120
kawa's Avatar
kawa
Bill:
What is the brand of the pump that keeps failing you, if you know?
