&%$*#@+$ PSD
Old Nov 12, 2007 | 08:23 PM
  #76
kawa's Avatar
kawa
Tim,
I am going to try that but there may not be enough room for it to completly unscrew as there isn't much clearance. But it's worth a try.
Rog
Old Nov 12, 2007 | 08:30 PM
  #77
Talyn's Avatar
Talyn
Yea, that trick takes some practice. Good luck Rog
Old Nov 12, 2007 | 08:32 PM
  #78
tjbeggs's Avatar
tjbeggs
Originally Posted by kawa
Tim,
Rog
I have heard of more than one person who said they did it. Hope it works!
Old Nov 12, 2007 | 10:10 PM
  #79
250turbo's Avatar
250turbo
roger, it can be done.i used vicegripes on rim of damper & tap on that. good luck kurt
Old Nov 15, 2007 | 02:14 PM
  #80
kawa's Avatar
kawa
Hot damn, I got the fuel damper (Disc) off it was a spap. I out a small set of vise grips on the edge close to a turbo strut and used a large screw driver and pried against the visegrips and it moved approx 3/8" and viola....I was able to spin it off and remove it. By the way I priced that dampner at the stealership and they get $115.00+. So you don't want to screw it up.
Now the bigger problem comes to light. The mount that the disc was screwed into is approx. 11/2" to 13/4" long so it moves the banjo nut/bolt way back under the turbo. There appears to be a devil lurking about me
If any of you guys that have removed the banjo nut/bolt (Whatever) please tell me how you did it. I would rather preform a self induced vasectomy than remove that turbo.
Help, please before I have the big one. This job is starting to make
me sick
Rog
Old Nov 15, 2007 | 02:22 PM
  #81
Action4478's Avatar
Action4478
You may have to bend a wrench , Or a notch in the ped(not the best Idea)...
Old Nov 15, 2007 | 02:32 PM
  #82
kawa's Avatar
kawa
Action:
Are you talking about bending a wrench for the Banjo Bolt? That's a good possibility. Hmmmmmmm
Rog
Old Nov 15, 2007 | 03:21 PM
  #83
250turbo's Avatar
250turbo
pm me kurt
Old Nov 15, 2007 | 04:03 PM
  #84
Action4478's Avatar
Action4478
Action:
Rog
....Yep.....
Old Nov 15, 2007 | 04:24 PM
  #85
MADVAN's Avatar
MADVAN
Rick
The Excavator wrench?
I have to make me 1 of them.
Bill
Old Nov 15, 2007 | 04:33 PM
  #86
Action4478's Avatar
Action4478
Originally Posted by MADVAN
Rick
Bill
Can we post a pic of it here without getting in to trouble?...
Old Nov 15, 2007 | 04:37 PM
  #87
Action4478's Avatar
Action4478
Banjo ratchet pic ...Here.....
  #88
MADVAN's Avatar
MADVAN
Only one way to find out
Should be no trouble this way. Direct.
http://rides.webshots.com/photo/2148...41601002NJvdfS
Bill
Old Nov 15, 2007 | 04:40 PM
  #89
Action4478's Avatar
Action4478
Bill
Webshot's is cool
Gun shy.....
Old Nov 15, 2007 | 04:47 PM
  #90
MADVAN's Avatar
MADVAN
You need a change for your screen name.
You must have 1,000 links
Your way to fast for me!
But i want one of those Excavator's
Gun shy=no/ trouble= follows me/ Slow= Yes!
Bill
