*17 hpop
Old Nov 9, 2007 | 01:05 PM
Strokin97's Avatar
Strokin97
*17 hpop
will a *17 hpop and a modded IDM be enough to push stage 2 or 3 injectors
Old Nov 9, 2007 | 01:33 PM
tjbeggs's Avatar
tjbeggs
by "push" what do you mean? run at there most effective or make them driveable? 2's yes either way. 3's no. Both will be best with Big oil and bigger fuel system. 3's both are nearly required to get the most power from them. Along with a properly programmed chip.
Old Nov 9, 2007 | 02:17 PM
Strokin97's Avatar
Strokin97
i have a fuel system juns not enough money to get the big oil so i thought one of a SD might get me by
Old Nov 9, 2007 | 02:31 PM
tjbeggs's Avatar
tjbeggs
Yeah it will get you by with 2's and probably 3's. Also keep your original HPOP then when you get another $900 you can so the DIY stealth!
Or you could build some DIY hybrid injectors and not have to worry about big oil at all.
Old Nov 9, 2007 | 02:56 PM
Strokin97's Avatar
Strokin97
wat would give me the most power with an H2E stage 2 or 3 with big oil or hybrids
Old Nov 9, 2007 | 03:29 PM
powerstroked162's Avatar
powerstroked162
A modified H2 and 530's from BDP with a set of Termy pumps will get you alot of power but you'll need to build up your motor if your gonna run that kind of power through it. a set of 2's on a 17* pump and stock fuel system with a d66 is a nice setup. Im seein 412 on fuel like that
A friend of mine made 550 on a SD pump.
Cowboy Steve
Old Nov 10, 2007 | 12:17 PM
Strokin97's Avatar
Strokin97
i already have the h2e and a few other parts im jus on a budget cause i have a 6.0 i jus bought to run back and forth to collage so my money is kina tight so the cheapest parts i can buy would help alot
Old Nov 10, 2007 | 02:37 PM
powerstroked162
BDP is who i would recommend you gow ith for your fuel mods. Terminator engineering gets my vote for twin HPOP's.
Cowboy Steve
MauleOne
Jan 14, 2012 10:10 PM
Jacksfirstdiesel
Feb 13, 2010 10:50 PM
custom_nirvana
Mar 24, 2008 07:03 PM
immastrokinnow
21
Feb 26, 2008 08:02 PM
Mark62
18
Sep 11, 2007 01:30 PM
