so i would be in no danger of breaking anything with throwing that code occaisionally or would it be worth going with a different hpop?
No, you wouldn't be In any danger throwing the code, just means that your running out of Oil which is understandable with stage 2's. If you have some $$$ and want a serious pump, Dieselsite just came out with a pulse pump. It ain't cheep, but It will supply enough oil to run anything
The code won't cause any problems. No need to let out or do anythign if the CEL comes on. Its just there to let you know.
Two pumps can be coupled together. Before the Pulse and The new Stealth pump thats what 2 of the 4 big oil product where. The Stealth and Terminator products are two pump run in line tandem.
I hear you Farm!! I drool all over my computer everytime I look at big oil!! With all the computers I have had to buy because of the drool I could have bought two big oil setups!! LOL
Farm how often do you set a CEL with your 2's? you running 15*?
TJ, I don't have a tuner yet. Just running the 10k. I've never set a CEL and I've laid into it pretty good and nothing happens.
I can hit 25 lbs boost no problem. The PROBLEM is I keep blowing intercooler boots off. My hot pipe is kind of mangled in there to work at the moment. It's about a 1/4 inch off of where it needs to be.
Tim, Looks like you need the Keyboard gaurd mod for your computer ... Note the image is from a pretty old school computer Nice!
Hahahah sorry Tim, I couldn't help it it was just too funny! Tell you what, Get youself a Pulse and I'll buy you a keyboard gaurd.. then you can think of me when you looking for a home for the 17º pump!!!
