Engine Pull "how to"?
Old Nov 8, 2007 | 09:24 AM
devildogmech's Avatar
devildogmech
Talking Engine Pull "how to"?
Hey all,
I'm new and am looking for a "how to" on pulling the 4 banger out of my father in-laws ranger.... I'm just doing a straight replacemnet with a junkyard motor.
Its a 99'.
TIA
Billy
Old Nov 8, 2007 | 06:42 PM
kevinwilly's Avatar
kevinwilly
Most manuals (Chilton, Haynes) have all the info on what you need to disconnect on the specific model.
Other than that, it's pretty easy. Maybe try Google for a basic guide if there's not one on here.
Just mark all the lines and electrical connectors really well and if you get stuck, post up with more specific questions.
It would be silly to write up a whole guide, in my opinion. A lot of it you can figure out on your own pretty quickly.
It's honestly not as bad as it seems.
Old Nov 9, 2007 | 11:05 AM
projectnitemare's Avatar
projectnitemare
It is smart to mark the electrical connections but the newer vehicles have unique plugs for each connection. A direct swap is pretty straight forward. Unplug everything you can find, you will need a fuel line disconnect tool, some basic hand tools and of course something to lift the engine out. A transmission jack is helpul but not required a floor jack will work too. Pull the starter so it doesn't get damaged. If it is an auto you will have to unbolt the torque converter from the flywheel; don't take the converter out. You might have to swap a few sensors and such to the junkyard engine. Make it look like the one that was in there and install in the reverse procedure. Really it isn't bad. On some jobs like pan gaskets and such I prefer to pull the engine. I change about 5-6 engines a year for people.
Matt
Old Nov 9, 2007 | 11:22 AM
kevinwilly's Avatar
kevinwilly
It's true about the electrical connectors. It's almost impossible to mis-wire a modern engine.
I like to label them with their approximate location, though "by throttle body", "left bank"... things like that. It just makes finding the mating half of the connector a lot faster.
And vacuum lines are another thing that will save you a TON of time if you label them well. You CAN figure it all out from scratch, but it'll take you ten times as long (if not more) to get it all back together correctly.
Old Nov 10, 2007 | 06:14 PM
devildogmech
I got the old motor out..... The new one will be delivered monday.
Wish I had labeled the vacume lines
Billy
Old Nov 10, 2007 | 11:41 PM
1983 3004x4's Avatar
1983 3004x4
there should be a label on the radiator support member that shows the way the hoses go.
Old Nov 11, 2007 | 01:19 PM
kevinwilly's Avatar
kevinwilly
Yeah, sometimes it's on the radiator support, sometimes on the valve cover. It's usually hard to understand, though.
It's not too bad, though. If you just look at it long enough, it should make sense where everything goes.
Good luck!
Old Nov 14, 2007 | 10:03 PM
rikard's Avatar
rikard
I use to get out the old Polaroid and take pictures of each side before I pulled out the engine. Digital works even better. Use baggies for small parts and fasteners with tag inside for ID.
regards
rikard
billy g
1978 - 1996 Big Bronco
Feb 2, 2012 08:34 AM
billy13
Dec 14, 2009 10:29 AM
*2fords*
Garage & Workshop
22
Aug 8, 2009 12:46 PM
devildogmech
15
Jan 10, 2008 01:40 PM
AZ 56 & 03
Dec 26, 2006 12:54 AM
