1978 - 1996 Big Bronco
New crate engine
Old Jan 22, 2012 | 08:47 AM
billy g's Avatar
billy g
New crate engine
I have a question for you guys. I currently own an 86 big bronco 5.0 302. It has oil leaks, water leaks and the timing cover is held together by JB weld. I think its time to get a new crate engine. but I'm not quite sure where to begin looking to get the best bang for my buck. any suggestions? Thanks
- Billy
Old Jan 22, 2012 | 11:31 AM
Edgethis's Avatar
Edgethis
Well that should carbed, correct? If I were you I'd drop in a reman 351. There's a few little things to change, but for the most part it'll drop in and bolt up. Get the same MPG but with double the torque.
Old Jan 22, 2012 | 12:06 PM
Beechkid's Avatar
Beechkid
- Billy
Their website isn't the best, but IMHO I would call gofastparts.com, they are besed in Redlands calif, prices are very good (yet to find anyone cheaper including shipping) and carry just about anything (including brand) crate engine known to man!
Old Jan 22, 2012 | 01:09 PM
billy g's Avatar
billy g
Thanks guys i will check out that website. also what parts will need to be changed if upgraded to that reman 351?
Old Jan 22, 2012 | 01:30 PM
Edgethis's Avatar
Edgethis
Do a search on here. I beleive its the flywheel and something with the harmonic balancer (not 100% sure).
Old Jan 22, 2012 | 11:13 PM
Torky2's Avatar
Torky2
If you are thinking of going the reman 351 route, check with the engine rebuilder first to see if they will accept a different engine (302) back as a valid core.
Old Jan 23, 2012 | 01:05 AM
GruesomeJeans's Avatar
GruesomeJeans
Oooor you could be really awesome and buy a 460 and drop that sucker in but also like torky2 said, the core might be an issue
Old Jan 23, 2012 | 07:32 AM
Edgethis's Avatar
Edgethis
Different bellhousing on the big block.
Good call on check for the core Torky.
Old Jan 23, 2012 | 09:11 AM
Raleigh1's Avatar
Raleigh1
Buy a newer (MAF) donor truck. It would be about the same cost as a reman engine, but you'll have EFI.
Old Jan 23, 2012 | 10:18 AM
Kemicalburns's Avatar
Kemicalburns
well first off that year would be EFI. whats your budget? can you do the work or will a shop have to do it?
if you upgrade to a 5.8 you will need to get the proper flexplate since i assume you have an AOD tranny correct?
RJM Injection Tech — Welcome has mass air harness's that are practicly plug n play. your efi is unique and pinned differently then the 87+ models so if you upgrade to maf wiring changes will for sure be necessary. a donor truck would work also if the miles are low and it doesnt have any front end damage
Old Feb 1, 2012 | 05:57 PM
unregistered guest's Avatar
unregistered guest
My 86 is carbed, but its a 351.
Old Feb 1, 2012 | 06:21 PM
AbandonedBronco's Avatar
AbandonedBronco
302 went EFI in 85
300 went EFI in 87
351 went EFI in 88
Old Feb 2, 2012 | 08:34 AM
masseysbronco's Avatar
masseysbronco
All 85 and up 302 trucks should be MPI full injection.
Clay frost
35
Mar 1, 2014 08:46 AM
mxkris
Colorado Chapter
Aug 17, 2004 06:15 PM
ddwood55
38
Feb 4, 2004 02:40 PM
RMCINNIS56
Apr 23, 2003 11:46 AM
AlM
Mar 16, 2001 09:00 PM
