Fuel Crisis
Old Nov 13, 2007 | 08:08 AM
  #121
aklim's Avatar
aklim
Originally Posted by MarkMoore
That's nothing, I got a 30# Pug......
Better put some heavy duty springs and shocks. No way the Ex will handle that sort of a load.
Old Nov 13, 2007 | 08:13 AM
  #122
VaSheriff's Avatar
VaSheriff
Originally Posted by FordCrusherGT
.... I have a 100 lb Rott as well.
When speaking of dogs, size DOESN'T matter.
My daughter has 5 pound Pomeranians that beat up my German Shepherd on a daily basis.
Old Nov 14, 2007 | 10:43 PM
  #123
1948f1's Avatar
1948f1
I have a 11 pound wiener dog. Size doesn't matter even with a wiener!
Old Nov 14, 2007 | 11:15 PM
  #124
guiri's Avatar
guiri
Hey, I've got a big Pug and a 140LB Great Dane. My 120LB Rottie is dead
Old Nov 15, 2007 | 04:57 AM
  #125
ukmat71's Avatar
ukmat71
Here in the UK, it cost me £170 fo fill her up from empty, that equates to roughly $340 for a tank full.
I think if the prices of gas get much more over here then i may consider converting it to propane as that can half the cost. (still expensive though)
to be honest i dont normally get that much in as they limit the amount you can fill up in one go, the pumps seem to stop at 99 litres.
but hey, i cant see another vehicle of this size that i can fit all the family in unless i go down the bus route. having the ex saves us taking two cars everywhere, Not so good for parking over here as the parking spaces seem to only cater for 12ft cars and not 19ft lol
Old Nov 15, 2007 | 06:31 AM
  #126
MarkMoore's Avatar
MarkMoore
I was watching a show on Discovery last night about 'future cars and fuel' - it got me thinking what could be done to my beast to make it more efficient. About the only I came up with was to swap the fuel line to stainless so I could run E85 - I think for the flex conversion I need new fuel lines and change to a different fuel filter. Now this would not increase the 'mpgs', but it would reduce the cost of a fill up and be more 'eco-friendly'.
Marcus - what does take to swap to propane? How would a truck this size perform with propane? Towing?... Probably not!?!
For me, towing only a few times a year, I could use a more efficient method 95% of the year and then convert back to reg gas for towing.
Old Nov 15, 2007 | 07:52 AM
  #127
aklim's Avatar
aklim
I had a flex fuel vehicle. Tried E85 once and NEVER WILL AGAIN. Power sucked and mileage sucked but other than that it was fine. I invistigated superchargers. I found out they had 2 different kits. One for flex fuel and the other for regular fuel. Difference was the contents. Flex fuel had no injectors while regular fuel had injectors and a bigger pump. Why? Because the flex fuel trucks had bigger injectors and a larger pump because they needed more fuel to do similar work should it come to it. Also, your injectors would have to be flex fuel compatible. Personally, I wouldn't but go ahead and sell your truck and get a flex fuel one assuming it is advailable if you want. I don't think you will save that much. Fuel will cost less but you will use more.
Old Nov 15, 2007 | 09:28 AM
  #128
MarkMoore's Avatar
MarkMoore
Yeah, that's kind of what I figured - E85 produces fewer BTUs that reg gas does.
I was really just trying to spark some ingenuity and ideas. I know my X will not get much better mpg that what it does now (typically ~13 mpgs daily commute), so the next alturnative was to see if there were less expensive fuel that could be used.
WeDo1983
Apr 17, 2020 02:38 PM
KenDillon
Large Truck
Sep 8, 2015 01:13 PM
chester7
Jan 21, 2011 05:51 AM
VaSheriff
Jul 23, 2009 08:06 PM
VaSheriff
May 20, 2008 08:57 PM
