Fuel Crisis
$350 in gas for a 1600 mile trip doesn't sound too bad. Figure that's a bit under half what you'd pay flying a twin-engined piston aircraft, and maybe 3/4 what you'd pay in a zippy single.
The best thing, though, is that when you divide up the fuel cost among the people who can go in an Excursion, a PSD version getting 20 mpg filled with 8 people ends up being 160 mpg.
Try THAT with a Prius!
This paragraph is proof that you, sir, are no mechanic, and furthermore that your experience with vehicles is surprisingly minimal for someone so old and wise. I can assure you that my V12 Jaguar (with 11.5:1 compression) does carbon up after driving it like a grandpa for a while. I can also assure you that I have done head gaskets on "modern" cars (newest one I suppose was 1995), and carbon buildup does, still, exist. So does sludge - although that is generally caused by people not changing their oil.
</RANT>
2) SLUDGE You are correct about sludge and no oil changes. We dont see sludge any more on most engines, simply because most people these days, especially if their cars are on lease and/or they want to preserve their warranty rights, DO change their oil, at least occasionaly. Yes, as one photograph posted earlier proves, it is still POSSIBLE to "sludge up" an engine thru a combination of gross abuse and lack of maintainence.
3) CARBON BLOW-OUT
I have never worked on (or even driven ! for that mattrer) a Jag -12, so I have no idea how their ignition and fuel ingestion systems work. I think what is confusing some of you younger people who do not have much mechanical knowledge, is what happens when you "floor" an older car that does not have computerized ignition and fuel controls. Of COURSE you see big puffs of black smoke, but this has NOTHING to do with so called "carboning up". More recent vehicles with computerized fuel injection and ignition systems simply wont do this unless there has been a major malfunction.
In one photograph, there was a comment about 1930's Cadillac V-16's. For that "poster", let me correct you - neither of the two versions of the Cadillac V-16 ( 1930-1937) or (1938-1940) had four valves per cylinder. Both had only two. The carbon on the valve is interesting, indicating the engine must have been worn WELL beyond "factory running limits" in order to by-pass that much oil thru the valve stem seals. What I see in that photo of that valve is consistant with a combination of a VERY worn engine, and a non "approved" oil. For those of you who THINK there is a difference in oil products that can lead to sludging up, you are partially correct.
For liability reasons, no motor oil manufacturer is going to risk being caught violating SAE-ASTM standards. Obviously, if someone has a worn out "oil-burning" motor they are going to junk or over-haul anyway, no point in wasting the money using an "approved" motor oil. You can still buy so-called "non-detergent single grade" oils, which state very clearly on their labling they do NOT meet modern standards. Yes, if you combine those oils, with a badly worn-out engine, of course you can generate the kind of sludge you see in those photos.
Bottom line - those of you kids who like to make noise, should just be more honest and admit you dont care about technical issues; you just want to do what you want to do, instead of inventing these obviously silly reasons for it.
Excursion @ 20 mpg x 8 people = 160 Pmpg
Prius @ 45 mpg x 4 (5 if you squeeze) people = 180 Pmpg
but then again the prius can't tow jack and you have to allow for the 'comfort factor
' Every vehicle has its purpose and its place. Even if you just drive an X because you want to, thats cool too. Basically, if you are willing to pay for it, by all means, drive whatever you want.
I do like the argument someone mentioned earlier about kids driving like kids being a choice to spend more $$ in the long run just like driving an X over something smaller is also a choice that will cost more $$ in the long run. I guess its all perspective.
Pmpg
It will COMFORTABLY hold 8 and more if you put a reverse fourth row in. If he does that, what are we talking, 250pmpg?
like i said, as long as people are willing to pay for it, i think they can drive whatever the heck they want to :-)
Isaac
Driving it would've been almost 800 miles. Good thing it was someone else's dollar paying for all that fuel...How's that for fuel economy?
The other thing I find amusing is how some people will actually overmaintain their cars, and then watch those items that they overmaintained fail. Example: One person I know flushes his coolant yearly, changes his oil at 2,000 mile intervals, and changes trans fluid at 10,000. He calls it cheap insurance. This guy also drives very sanely and conservatively.
75,000 miles on his Jeep that he's owned since new: Radiator needed to rebuilt and the transmission is now dead.
What amazes me is when I see some people who don't maintain a thing on their cars, and they're running at 150,000-200,000 miles, and the things are actually still running and driving fine, despite having original everything (well, maybe not motor oil). Boggles my mind, I know I wouldn't be that lucky.
Maintenance is good. Overmaintenance is costly. There is no benefit to changing oil at 2000 miles if 5000 miles will do. I'd get an oil analysis before I go any further than manufacturer recommended changes on EITHER side of the fence.
As you said, it is luck. A guy bought a brand new Lexus and didn't get it out of the dealer lot before it died and all sorts of problems occured. I don't know but I would assume he is pissed.
On another note, theres a certain dinasaur in this thread thats about as sharp as a marble when it comes to modern automotive technology. But we wont name any names. Ok ill be the adult and end it here, no more comments about that anymore, dont wnat to start any fights or anything.
And you know what? I'm 46 and sometimes it's fun to make noise and have fun!!! Keeps me young!!
Beth
Proud owner of a 2000 Excursion that makes noise and makes me smile!!
