Sponsored by: Auxito
Rear Wheel Locking up in Reverse
Old Nov 2, 2007 | 05:35 PM
bmgnitro's Avatar
bmgnitro
I have a 2001 F150 XLT, 67,000 Miles. When i back up the drivers side rear wheel locks up, it doesn't do it all the time. There is no pattern, i can back up 10' before it happens sometimes. A horrible grinding/cruntching noise stops the truck. I have had it looked at and nothing was found. What can i look at next?
any ideas would be helpful
Old Nov 2, 2007 | 06:00 PM
steve(ill)'s Avatar
steve(ill)
just aabout has to be the brakes? i would take both sides off and look again. how about putting axle on jacks, take wheels and tires off. start truck and put in reverse and watch. then take brake drums, or disc off and look.... could it be emergency brake? do you have disc rears?
Old Nov 2, 2007 | 06:16 PM
bmgnitro's Avatar
bmgnitro
4 wheel disc brakes, i had pads done 10 days ago, i thought mabe they were the wrong ones or a bad set so today i had new ones put on and the same thing happens. Very frustrating, you never know when it is gonna happen. I thought about the E-Brake, but whats there to check on that? I works fine
Old Nov 2, 2007 | 07:57 PM
steve(ill)'s Avatar
steve(ill)
take the disc off and check the e-brake. tha shoe falls apart and gets stuck aginst the small drum. normally it dont "work fine".
Old Nov 2, 2007 | 09:41 PM
kharmaguru's Avatar
kharmaguru
Mine did exactly the same thing, it was the E brake. The E brake is seperate from the disc caliper. It is a little drum assemble inside the disc (called drum-in-hat).
Old Nov 3, 2007 | 01:06 PM
bmgnitro's Avatar
bmgnitro
that was the problem, the e-brake shoes fell right out after removing the disc.
Thnks for the help.
Old Nov 3, 2007 | 07:14 PM
steve(ill)'s Avatar
steve(ill)
to fix it permanently, put the shoe in the nearest trash can, put the disk back on the truck. wont fail a second time.
Old Jan 13, 2011 | 04:34 PM
seadooxp's Avatar
seadooxp
My right rear tire is randomly locking up on me when I back up but not going forward, I think I just found the answer I was looking for lol.
hurst1979olds
29
Aug 30, 2016 10:01 PM
Camuchi
Apr 11, 2016 07:46 PM
LostAngel
Mar 15, 2016 08:32 PM
gordo2
Offroad & 4x4
15
Mar 29, 2010 10:09 AM
DSMMH
Mar 8, 2010 11:01 AM
