[updated:LAST EDITED ON 01-Sep-02 AT 08:29 PM (EST)]I don't care who says 300 6's can not do a burnout, This truck has 28 spline 2.75:1 Rear end gears and no mods to the engine with the exception to a B&M LINE LOC... It Does nice burnouts the only reason I had normal 15's was the fact of $375.00 A tire for the BFGOODRICH tires This was done at lacombe in Alberta and if it is in a water Box it will do a burnout with the 35" tires Bad for the Axles 4 I have broke Don't do burnouts 80 Km from town on Dry Pavement with a Neutral Drop IT HURTS. POSI will occur with the 15" tires but a 300 still can do one TORQUE!!!YA
Question should I go with Stronger 31 spline diff with 3.55 gears or a 31 spline 4.56??? 9 Inch Help This truck really sucks on the highway
Check IT OUT!
http://www.geocities.com/coolfords2002/
Good Point
It has a 9" Rear with 2.75:1 Gears with 28 spine axles and I would like to have a strange 35 spline diff..(Really Sweet harden Axles) 3.00-3.90 Gears Im looking for just a Shur-loc,detroit loc or a limeted slip rear end and would appreciate any lines on one
Thanx
my 93 will do nice burnouts if i could get my tires to break loose, i have a posi and its hard. also 31x10.50x15 bfg ATs arent the easiest to break loose and i dont want to do it often, they are expensive. i power brake (auto) once and a while but i only "accidentally" dropped it outta neutral once, it knocks the **** outta the tranny and rears so does power braking. but my truck will do a nice job of laying a patch of rubber if i pull out on a turn or if its a dirt road to paved.
I've been able to do a few regular burnouts with my truck, however i believe it was because one tire was balder than the other. Went back to look at my patch, and there was only rubber from one tire. OOOOps, oh well, it was fun, and im still scraping rubber chunks from the wheel weel.
[updated:LAST EDITED ON 03-Oct-02 AT 10:13 PM (EST)]Hey Greenflareside Did you see the grey and white 1958 Mercury at the ponoka car show/dipstick races this september, that is my dads. Your truck kicks.
Steve
PS My dune buggy will do one hell of a burn out with my winter diggers on my ford 9 rear with 3.73 gears, check it out!
1970 f-100 Custom 302 2bbl 4 on the floor, my "economy" machine 1970 F-100 Sport Custom 390 2bbl 3 in the tree with factory overdrive.
1978 F-150 Custom turned into a dune buggy 300-I6 4 speed
Im a typical teen, i just have to change it!
the 31 spline is the way to go. i have an 86 f150 4x4 on 38" tires with a np435 and 205 transefer case. i dont like to get stuck so it will go from first to reverse often and with great force. i have now gone through 2 tranies, and still have the same axles that i put in it 4 years ago. these are the strogest 1/2 ton axles out ther in my opinion. i have checked the splines on them several times and they are still fine. if you wont strength, go with them.
burn outs r fun......... i got a 69 4x4 4speed with granny with 2hi 4 hi tranfer case mmmmmm nope no 2lo just 2hi ..neutral..4 hi... shortbed 300 6cyl mini spool rearend 4:11s...... ive pulled two dead chevys , ones hubs wouldnt lock the other wouldnt crank due to over heating ,,, out of a hole 10 foot long and guessing 3 to 4 feet deep in granny and did not get above idle......mmmmmmmmm love this truck ..was offered 3500.00 that nite for it...... no i didnt sell ..pulls like skider and drives well some what good and can dump clutch and smoke it but got 31 spline axles.....but mini spool is hard on tires but cheap posi unit ......... red skider
cough cough i did a nice burnout w/ my 83 str8 6 4x4 31's
smoke it up at a set of lights one morning.
redid suspension everythingand replaced the front and rear axles 355's sweet
:-staun
My 84 F-250 4x4 will ROAST em' with a 300- unfair advantage, it's quite well built. Still, 265/75R16 tires don't stand a chance. I put them on in January, and burned them off by May. My favorite is to pull up next to someone, take off normal, then punch it into 3rd. It tries to swap ends, smoke everywhere. Just check for cops before insanity.
