Burnout Rubber Removal :)
Old Jun 13, 2007 | 02:31 PM
TheTedster's Avatar
TheTedster
Well, I did a nice burnout last night with the v10 f250 and melted the rear tires a little more than I thought, and this morning when I when outside I could see the result of that burnout in the form of melted rubber bits all over the rear portion of the truck, bumper, etc.
Soo.....I took it to the local selfwash car wash and used the pressure washer on it for a bit, but no luck. Finally I went to walmart and picked up a spray can of bug and tar remover from turtle wax, which stated that it's safe for clear coat and chrome surfaces. Well, it only took about 20 minutes of rubbing and I finally was able to get all of the rubber bits removed - it did get a bit messy when the rubber started to smear a little, but that was easily resolved by switching out rags frequently. I just thought I share that this stuff worked really well, and did not affect the paint at all and the truck is now back to it's pre-burnout appearance.
I learned my lesson, and won't be doing anymore burnouts like that for awhile.
Cheers to Bug & Tar Remover!
Old Jun 13, 2007 | 02:36 PM
1fastcavi's Avatar
1fastcavi
yea, we used to have a pine tree over our drive way, sap got all over the cars. could NOT figure out how to get it off.. grabbed a thing of bug and tar remover and it worked wonders!
Old Jun 13, 2007 | 03:15 PM
arctic y block's Avatar
arctic y block
Fender flares and mud flaps and let the tires burn. ARHHHH AHHHH
Old Jun 14, 2007 | 04:40 PM
FarmForward's Avatar
FarmForward
A trick I've seen used by some "run-what-ya-brung" racer types (street-legal cars that they run on a dragstrip) is to put a thin film of petroleum jelly on the sheetmetal just behind the rear tires. The rubber sticks to that and will usually wash off with a pressure washer.
Old Jun 14, 2007 | 04:41 PM
arctic y block
Paint that area Black
Old Jun 17, 2007 | 03:09 AM
bla1879's Avatar
bla1879
i have always been able to just brush it off, if you clean it off the same night that you do it, it will usually just brush right off, at least thats what i have found in my experience
Thoroughbred Diesel
General Diesel Discussion
Mar 16, 2014 03:31 PM
UP_There
15
Apr 20, 2008 10:23 PM
wintremute
General Automotive Discussion
Aug 2, 2005 12:28 AM
modru2004
15
Dec 13, 2004 06:43 PM
Squiggy
Dec 5, 2004 08:08 AM
