Frantz Oil filter analysis results
Old Oct 26, 2007 | 09:53 PM
bkcowboss's Avatar
bkcowboss
Thumbs up Frantz Oil filter analysis results
Here are the Quotes from blackstone, same oil same truck first quote is 1000 miles, second quote is 2000 miles. I used Hot Shot secrets as an oil additive, works like a charm as you can see they say the oil is real dirty for a 1000 miles, well, that is cause the HSS is doing its job, it has definitely helped, and blackstone speaks for the bypass filter.
"BRYAN: Thanks for the note about the additive that you used. We found fuel at 2.0% so we aren't sure how well your additive is working though. This level of fuel dilution isn't a problem, though it is more than we like to see. We don't get too worried about fuel until it reads over 2.0%. Wear generally looked good but copper and lead (bearings) was high for an oil run just 1,000 miles. Universal averages are based on an oil run of ~5,200 miles. We suggest running this oil another 2,000 miles then check back with another sample. Hopefully fuel doesn't increase."
"BRYAN: Insolubles (oil oxidation due to heat, use and blow-by) were low at 0.2%, which shows excellent oil filtration and that your by-pass filter is working well. We're glad that you haven't changed this oil because it can easily be run longer. Universal averages for the 7.3L are based on an oil run of ~5,300 miles. We suggest running this oil another 3,000 miles and resampling for another look. Wear was generally low and other than a minor amount of fuel no harmful contaminants were found. Fuel at 1.0% isn't a problem. All in all, a good report at 119,500 miles."
Pretty significant difference in reports, I am trying to figure how to post the hole thing, but generally there was little to no increase in wear metals and insoluables, a decrease in fuel (fuel in the oil is from short operating times, I rarely get up to temp, only 4 miles to work) I would now highly recommend a frantz filter without hesitation. Any questions feel free to PM me.
Old Oct 26, 2007 | 09:59 PM
tjbeggs's Avatar
tjbeggs
Brain you can post the report in Webshots by using the snapshot icon in Adobe. its the camera pic next to the zoom button. Then paste i paste it into Microsoft Digital Picture. then save as JPEG. You might also be able to do that in MS Paint as well. here is an example of mine that are posted. Notice I cut off the personal info but left the vehicle info
Old Oct 26, 2007 | 10:09 PM
bkcowboss's Avatar
bkcowboss
That will work perfect, I knew somebody would set me straight, thanks TJ....
Looks like I am going to have to do it monday, at work my dial up does not like the download.
Old Oct 26, 2007 | 10:18 PM
tjbeggs's Avatar
tjbeggs
BTW everything sounds good! I am looking forward to your full reports! Give's me some motivation to change mine more often!
Old Oct 26, 2007 | 10:23 PM
bkcowboss's Avatar
bkcowboss
Thanks I just wish my internet connection wasn't killing me, I am connected at a whoppin 12500 bytes per second (feels like per minute)
Old Oct 26, 2007 | 11:48 PM
c00nhunterjoe's Avatar
c00nhunterjoe
dont feel bad, i am paying for 3 gig but only connected at 750kb, verizon has been trying to switch it since feb. i feel the pain
Old Oct 30, 2007 | 06:08 PM
bkcowboss's Avatar
bkcowboss
Here are the oil sample documents from blackstone. Note that the second 1000 miles the increase was no more than 0.1 or 10% of the first thousand miles, and there was a decrease in Tin, if anybody has any questions please feel free to ask
---standby I will make them bigger, in a minute---
Old Oct 30, 2007 | 06:31 PM
kawa's Avatar
kawa
Brian, I am familuar with the Frantz by pass filters of yesteryear (50's) that utilized a roll of toilet paper. Is this Frantz filter that you are using use a toilet paper roll as well?
Rog
Old Oct 30, 2007 | 07:10 PM
tjbeggs's Avatar
tjbeggs
Rog
Same thing!! proven tech!
Old Oct 30, 2007 | 07:14 PM
bkcowboss's Avatar
bkcowboss
Sorry it took so long, I am technically challenged
Old Oct 31, 2007 | 02:29 AM
caseydudem's Avatar
caseydudem
Question Samples
How do you guys do those samples? What do you send it in? What does it cost? They seem very informative and I would like to do a couple on mine. Thanks
Old Oct 31, 2007 | 06:26 AM
bkcowboss's Avatar
bkcowboss
Blackstone labs is a sponsor, click on their link, and request an oil sample kit. I request 3, then when you get an oil sample send it in with a check for 22.50 and the email, and snail mail the results back to you. That is the only way to safely extend oil change intervals, notice that it tells you the oil saturation level on soot, fuel contamination and if you have injector o ring issues it can also tell you if the oil you are using is doing its job.
Old Oct 31, 2007 | 07:55 AM
tjbeggs's Avatar
tjbeggs
Looks good Bryan! keep on testing it will give you a nice base line to look for trouble.
bismic
Aug 10, 2015 10:35 AM
Steel Toy
Vehicles for Sale
May 9, 2014 07:46 AM
nghtrgr
May 22, 2009 02:07 PM
76f350spercamprspeal
15
Feb 18, 2008 05:14 AM
JT5509
General Automotive Discussion
Sep 26, 2006 05:07 PM
