small engine repair
Old Oct 26, 2007 | 07:17 PM
Lee250's Avatar
Lee250
small engine repair
I am rebuilding an 11hp 4stroke Tecumseh generator engine and was wondering if any one would know about what the piston ring end gap should be. I was going to use the specs for my truck which is .010-.020 but my dad said that since this engine is air cooled that it runs hotter and the gap might need to be bigger. Any advice?
Old Oct 26, 2007 | 08:39 PM
Buckarcher's Avatar
Buckarcher
Try this link, check page 87. Don't know if one of those models are yours, but there are two different specs listed. Like you said and a .07-.17. They seem to only list 4 sets but they are 4 cycle OHV's
http://www.smallenginesuppliers.com/...nformation.pdf
It comes from this page.
http://www.smallenginesuppliers.com/...ine-specs.html
Old Oct 26, 2007 | 11:59 PM
ford2go's Avatar
ford2go
If you find the tecumseh website, I think that they have most of their service manuals online
ford2go
Old Oct 27, 2007 | 12:00 AM
jake00's Avatar
jake00
def. look in the service manual
Old Oct 27, 2007 | 01:39 PM
00BlueOvalRanger's Avatar
00BlueOvalRanger
Try here:
http://www.cpdonline.com/692509.pdf
Old Oct 27, 2007 | 09:28 PM
Octane's Avatar
Octane
Your dad is right. Air-cooled engines are built with looser tolorances to allowed for a greater amount of expansion due to the high combustion chamber temps.
I dont know what the gap should be, but hopefully one of those links that the others provided are of some help to you.
Old Oct 28, 2007 | 07:45 AM
ckal704's Avatar
ckal704
Typical ring end gap reject sizes are .035" for either of the two compression rings (top two) and .045" for the oil ring.
If the bore hasn't changed and the rings are new, you'll usually find them to be about .015".
So, if you are anywhere between .015" and .025" that would be considered acceptable and the engine should have ample compression to make the power that you expect.
Just be sure to measure your bore if your ring end gaps appear to be beyond reject. The cast iron rings are designed to wear at a faster rate than the aluminum cylinder (yes, it is true!), but if the cylinder is worn (excessive dirt ingestion through the carb or in the oil), new, standard rings may not help matters much.
Old Oct 28, 2007 | 08:26 AM
pfogle's Avatar
pfogle
My first question is why rebuild a tecumseh? My advice is buy a real engine (kohler or even a briggs and scrap-iron)... But since you're already into it I think some really good advice has been listed already.
Old Oct 28, 2007 | 09:01 AM
wizzard351's Avatar
wizzard351
i found this place a while back,its kinda like the FTE of the small engine world
http://www.smokstak.com/forum/forumdisplay.php?f=3
earnhardtracer38
May 2, 2007 09:50 AM
RyanMiller
Jan 9, 2006 10:21 AM
Hi Ho
18
Aug 24, 2003 10:28 PM
shotgun_000
36
Jun 25, 2003 10:22 AM
punkndrublic
Mar 28, 2003 10:28 AM
