Head scratcher
Old Oct 24, 2007 | 09:30 PM
John Durant's Avatar
John Durant
Head scratcher
I have a 1987 F-250 4x2 with 5.0L and 4 speed mannual transmission. I replaced the engine with a new long block. Here is the problem, when the engine gets to operating tempture it will not take fuel. I also back fires thru the throttle body. I have replace all sensors, new fuel pump and filter. I have removed the thermostate and still have the problem, just takes longer to heat up. I have had it to several shops and no one can figure it out. HELP!!!
Old Oct 24, 2007 | 10:05 PM
ford_boy_1996's Avatar
ford_boy_1996
Maybe have it put on a computer or did you check your timing
Old Oct 24, 2007 | 11:23 PM
big Red_25's Avatar
big Red_25
I know you might have already thought of this. Where are the fuel lines run? Are they close to anything that might cause them to be vapor locked? The only sympotm that is throwing me off is the fact that the timing is to advanced.
Old Oct 25, 2007 | 08:31 AM
blue68f100's Avatar
blue68f100
On the long block, did you install a new timing gear set. And is the timing set correctly. Back fireing through the tb indicates timing. I would install the stat back in, without one it will never get to operating temp in a timely manner. Also make sure you fuel pressure is correct on the rail. if it's low you will run real lean and rough.
Old Oct 25, 2007 | 11:25 AM
John Durant
I did reinstall the stat. Timing gears and chain are new. Truck starts and runs pretty good when cold, but will not take fuel once it gets to operating tempture. Acts like it is vapor locking but I did not think an EFI system could vapor lock.
Old Oct 25, 2007 | 12:07 PM
blue68f100's Avatar
blue68f100
Yes a EFI will normal not vapor lock due to it circulate excess fuel back to the tank with the regulator. What is your fuel pressure running on the rail? >35psi. Also what is your vacuum running at idle?
Do you have a scanner you can connect and look at inputs. Interested if the problem only exist when the computer goes into closed loop. Also retrace all of the vacuum lines. If your vacuum is low, uses propane gas and snoop for your leak.
CrazyMiracleMan
13
Oct 16, 2012 03:35 PM
terryq
2004 - 2008 F150
Oct 31, 2010 07:41 PM
clydeford
New Member Introductions
May 10, 2009 01:20 PM
4DADDY
1997 - 2003 F150
Sep 11, 2007 07:07 AM
jonvanzanten
Sep 1, 2007 10:18 PM
