Need some help with wiring.
Old Oct 24, 2007 | 08:15 PM
stang_crazy_gt's Avatar
stang_crazy_gt
I need to either find some good wiring diagrams or get some help here. So heres my situation.
I have a cab from a 1968 F350 so it has all the dash wiring. Well we put the steering column from a 1972 f100 in it since it had no column in it.
We needed to hook up the steering column wiring to the connector under the dash.
Well we are unable to. The steering column from the 72 has 1 7 prong black connector.
The 68 dash connector(s) has 2 plugs a 2 prong plug & a 5 prong plug.
So i need to figure out which wires go to what so i can make a jumper harness so i can get the turn signals, ect.. working.
Here are the colors of the wires ect if its any help. I hope they are correct, it was hard to tell on a few.
The 1968 F350 dash connector(s)
2 prong plug
green/tan stripe
orange/blue stripe
5 prong plug
white/blue stripe
green/white stripe
blue/green stripe
grey
green
1972 steering column connector
7 prong plug
blue/yellow stripe
light blue?
red/black stripe
green
yellow/black stripe
green/white stripe
white/blue stripe
A few of the wires are the same color on both ends so im sure they hook together, but not sure about the rest
Thanks in advance and sorry about the long post.
Old Oct 24, 2007 | 10:51 PM
mrcman58's Avatar
mrcman58
Talking wiring
there is a small skinny tool for removing those prongs from the connector. sometimes you can use a very thin screwdriver to slightly bend in the locking part of the prong. but you need to slightly push the wire into the connector so it will collapse easier, if you can get ether the mating 2 connectors or the mating single connector you can convert it without a lot of trouble. a few of the wires are still color coaded the same but a few are not as you already know.
I had done this several years back and did a trial & error to figure them out,
I just had a look around to see if i still had my diagram i made then but couldnt find it. if you dont have it figured out by tomorrow i will look on my old ford that i did that to and write down the formula to match your wires. you can also contact FTE member numberdummy he might have that wiring info handy.
Old Oct 25, 2007 | 12:14 PM
blue68f100's Avatar
blue68f100
This may help you, noticed it does not match yours completly
Grn ----------- Stop Light
Wht/Blu ------- RF Turn Signal
Grn/Wht ------- LF Turn Signal
Orn/Blu -------- RR Turn Signal
Grn/Orn -------- LR Turn Signal
Wht/Red ------- Hazard Flasher
Blu ------------ Turn Flasher
Ylw ------------ Horn
Dk.Blu ---------- Horn Ground Gnd ----
Nate66stepside
Nov 16, 2015 03:46 AM
79Supercab
Feb 22, 2015 10:16 PM
Desarata
Feb 11, 2014 08:50 PM
thaugen
Large Truck
Jul 31, 2012 09:23 AM
mikewrt
Oct 19, 2003 10:49 AM
