To add, the Overload spring is normally considered the big fat leaf at the bottom of the standard spring pack that doesn't hit the rest of the pack when the truck is unloaded, but will when it is loaded.
I have that one too, it almost looks like flat bar stock and about 1/2" thick... I'll have to get the dealer to print out the build sheet for this truck to see what it came from the factory with. Thanks for the tip!
Do not forget free leving kit. If you look at trucks with the camper package they sit almost level. I think mine might ride a little stiffer but I like that in a truck could be the fx4 package though. The rear sway bar should help reduce body roll, not sure the only new truck I have drivin is mine so I only know how the camper package handles and I know it sits pretty level in quick sharp turns.
All the SD trucks, and most trucks with leaf springs, will have the overload on the bottom. Just clarifying the terminology!
The rear sway bar does make a difference. After the accident, I hadn't put it back on for a while. When I did I noticed a big difference in cornering. It oversteered marginally before, and was pretty neutral after. I think the auxiliary springs are more for stability than for load carrying. As the truck comes over to one side it will hit the aux spring on that side limiting roll and sway. It is likely to do that more with something top heavy like a slide in or a salt spreader in the back! IMO the camper package is the best suspension upgrade you can get. Depending on equipment it gets you heavier front springs, but maybe not the heaviest though.
Time to take them both in for warranty work. They should be at the bottom of the spring pack. The "auxiliary" springs should be on top.
biz
Why not? They put the headlights in upside down.
I just looked again - the bottom leaf in the pack is shorter and thicker than the rest of the pack, with slightly less arch, leaving about 1/2 inch between it and the leaves above it at its outer end. There is a long single leaf on top, spaced several inches above the main leaf, with brackets on the frame holding rubber bumpers a couple inches above the single leaf.
Now, when I add weight to the truck, it is obvious that the main pack will touch the bottom short spring long before the rubber mounts contact the single leaf on top. In fact, with the 5'er hitched, (approx 2500 #), the rubber bumpers still don't touch.
So, if the overload springs are on the bottom, and the auxillary springs are on the top, why does the overload come into play before the aux springs?
As I recall, my '05 F250 was set up the same way. Splain that, Lucy.
I have...
The auxiliary spring is not for load carrying on the lighter trucks (250/350). It is for stability. The overload spring is part of the progressive nature of the main spring pack. I've had 4000lbs in my bed and the aux springs still weren't riding on the bumpers. They would only hit if it was off to one side or the other. They limit the amount that the truck will roll to one side or the other.
So what you're saying is I don't have overload springs per se....just a stacked progressive load main spring with auxillary on top?
Eeeh I guess. I've always referred to that big spring leaf on the bottom the overload spring. Not much of a spring really like you noted. Not sure if there is a different terminology for the "auxiliary" springs that actually take load instead of stabilize. I always thought the aux springs on the 250/350 were for extra load control, but when I had the 4k lbs in mine, I realized they weren't and started to think about it. There was just no way they could be expected to hold an extra load. The 450's etc have springs that are arched more to "kick in" sooner. They will actually load down on them, same with the chevy's too. The 3500 dually has a 2 leaf pack that will support the load on both sides.
