76 Camper Special and Headers
Old May 20, 2004 | 09:44 PM
Brian460's Avatar
Brian460
We have a 76 F-250 Extended Cab Camper Special with a 460 in it and we can not find a set of headers that will work with the camper special package.
Thanks for any help
Old May 21, 2004 | 12:44 PM
LxMan1's Avatar
LxMan1
Why would it be different for a CS in the front?
Old May 21, 2004 | 01:22 PM
dfisher1's Avatar
dfisher1
Brian,
From what I can tell, the only way to put headers on a 460, is to use fender well headers.
Good Luck,
Do a search on 460 and headers. You'll find quite a few post.
KingFisher
Old May 21, 2004 | 03:21 PM
Brian460's Avatar
Brian460
We are not sure why CS is deifferent but, every header book that lists '76 F-250 with 460 has a foot note that says "will not fit camper special". We think there is a extra cross member there for the radius arms.
We also thought about fenderwell headers which would be fine except we don't think they will clear the steering box.
Old May 21, 2004 | 06:27 PM
19gator55's Avatar
19gator55
I've got Hooker Headers on my '77 F350 Camper Special and they fit fine. Be prepared though to unbolt the passenger side motor mount and jack up the motor to install them. My truck is a 460 2WD if that helps! I'm getting ready to add some Flowmasters as the no name glasspacks I have bolted up now just don't cut it.
Old May 22, 2004 | 01:49 PM
Brian460's Avatar
Brian460
You would happen to have a part number for those hooker headers would you? Also some pics on the underside would be helpful if you can.
darren_palms
Dec 19, 2014 05:13 PM
Animal28
15
Nov 18, 2012 11:20 PM
jlasater
24
May 15, 2005 08:49 PM
