6 speed fluid
Old Oct 14, 2007 | 11:35 AM
cobarjet's Avatar
cobarjet
6 speed fluid
Need to change oli in the tranny looking for input on what fluid/oil to use in it
Old Oct 14, 2007 | 11:47 AM
F350-6's Avatar
F350-6
I've never had any trouble with the recommended ATF. Some prefer a synthetic. Royal Purple is a name that gets tossed around a lot.
Old Oct 15, 2007 | 11:08 AM
Fat Diesel's Avatar
Fat Diesel
Mobil 1 Syn ATF is what i've put in the last three times. I've even tortured it to 235* without an issue.
Old Oct 15, 2007 | 11:34 AM
cgl's Avatar
cgl
Mobil 1 Synthetic ATF gets my vote.
Old Oct 15, 2007 | 03:55 PM
jtharvey's Avatar
jtharvey
The manual tranmissions in these trucks use ATF? Seems like that would be too thin for a manual.
Old Oct 15, 2007 | 04:09 PM
F350-6's Avatar
F350-6
You would think so but they've been doing this for several years. It actually holds up well.
Old Oct 15, 2007 | 04:19 PM
jtharvey's Avatar
jtharvey
Do you guys know of the new '08 trucks have the same manual trans in them and call for the same fluid? I've got a friend that owns one and wants to change his fluid, but the owner's manual only states Motorcraft Manual Transmission Fluid. Is this just rebadged ATF? Seems it would be easier for them to just spec ATF in the manual.
Old Oct 15, 2007 | 07:25 PM
cobarjet's Avatar
cobarjet
thanks to all for the infor
Old Oct 17, 2007 | 09:47 AM
cgl's Avatar
cgl
My 02 manual uses ATF. The 08 specs:
Manual transmission fluid
5.8 quarts (5.5L) Motorcraft Full Synthetic Manual Transmission Fluid
Ford part number : XT-M5-QM / WSS-M2C200–C
What the difference is, I don't know.
Old Oct 17, 2007 | 10:55 AM
03_PSD's Avatar
03_PSD
how much fluid do the zf6's hold?
Old Oct 17, 2007 | 11:26 AM
Izzy351's Avatar
Izzy351
Yep -- my '84 Mustang's T5 had ATF in it. I converted to 75W-90 syn gear oil, then broke it. Twice. It wasn't the oil's fault though. I was racing it both times --2nd gear in those things were very fragile. That's why I swapped it to a C6 with the bored 351W...
No breaking that one...
EDIT: What the heck is "Full-Synthetic Manual Transmission Fluid"???
Joe
Old Oct 17, 2007 | 11:36 AM
rbaker6336's Avatar
rbaker6336
yep bought a new 1969 f350 had atf in it
devink
Aug 14, 2007 01:37 PM
dzk007
Aerostar
Apr 13, 2002 11:13 AM
StrangeRanger
Nov 14, 2001 03:32 PM
fiddy
Jun 10, 2001 10:15 PM
EJonesJr
Jun 3, 2001 09:53 PM
