tranny fluid and filter change
Old May 31, 2007 | 06:59 PM
devink's Avatar
devink
How many quarts on tranny fluid is required for a fluid and filter change?
Old May 31, 2007 | 07:53 PM
TMartinLVNV's Avatar
TMartinLVNV
With just a drain and the replacement of the inline filter, it is about 8 qts.
LOOnatic's Avatar
LOOnatic
On the 6.0 the internal tranny filter doesn't do much but the external one under the cooler in the front end near the passenger tire wheel well does.
If you change that and drain the pan (it has a drain bolt) your looking at about 8 or so quarts.
It takes mercon sp only available from Ford.
Try to drain the fluid when it is hot and up to temp.
69cj's Avatar
69cj
External filter = approx. 1 qt.
Internal filter = approx. 7 to 8 qts.
Have never done flush but have read approx. 22 qts.
Only use Mercon SP
Old Jun 1, 2007 | 12:15 AM
blackhat620's Avatar
blackhat620
Total fluid change is 17.5 quarts. Here is the link to the write up in the Tech folder on how to flush the transmission yourself.
http://www.truckblog.com/story-582-h...t_transmission
Hope this helps
Old Jun 1, 2007 | 08:37 AM
devink's Avatar
devink
Thanks Guys
Old Jun 1, 2007 | 12:45 PM
burninfilm's Avatar
burninfilm
I am getting ready to do the same thing. The little external filter looks like it might hold a pint.. Also, I have not been able to accurately determine which filter I actually use. My dealer says it depends on the vin (I have a 2006 F250), but all of the parts look-up say F-145 or equiv. Yesterday they gave me a quote of $80 for a filter after asking my vin and today a quote of $30 with no vin necessary. I don't have much confidence in this dealer so think I will get a wix, motorcraft or somebody elses..I have to buy my fluid at the dealer, but not my filter..Oh..The service manager says they change the filter with their $199 flush, but since they don't stock any, I doubt it. I asked about that and was told that when they need them they get them from another dealer...No confidence again.!!!! I am going to get a filter, 8 qts of fluid and do it myself!! Any ideas?? Thanks, Bob <><
Old Jun 1, 2007 | 12:56 PM
blackhat620
Bob,
Here is a link to purchase fluid and filters online, and if you spend $150 the shipping is free.
http://www.dieselfiltersonline.com/X...-Xt-6-Qsp.aspx
http://www.dieselfiltersonline.com/F...er-Ft-145.aspx
Hope this helps
Old Jun 1, 2007 | 01:13 PM
burninfilm's Avatar
burninfilm
Thanks for the links...Bob <><
Old Jun 1, 2007 | 04:47 PM
burninfilm's Avatar
burninfilm
Have a Baldwin filter on the way ($14) from the local parts house..$5 per qt at the dealership for the fluid, so I should be set..Bob <><
Old Jun 16, 2007 | 08:13 PM
slowmans's Avatar
slowmans
changed my filter this week, external one... i got it to come off with a 3/4 rachet no proble it was pretty dirty, only 26k on the ticker... i think im gonna drain the fluid and refil every 15k from now on. The internal filter doesnt need to be done until 60k right???
Old Jun 17, 2007 | 10:03 AM
Lonewolftx's Avatar
Lonewolftx
Lightbulb
The external filter part # is motorcraft FT-145 $19.99 at auto parts store. Also Wix parts #57702. It takes a 22mm socket and when I did it last Thursday less than 4 oz leaked out into a jug I had ready to catch the overflow. Just put new filter in and screwed it back on.
Old Aug 10, 2007 | 09:37 PM
slowmans's Avatar
slowmans
well im gonna drain the pan and refill tommorrow morning, i think im gonna do this every 15,000 miles i have 29,000 on the o.d. if ive read right it only takes about 8 qts for the drain and refill of the pan? ive got 10 qts any way! i found a place onlinie that sells sp for 3.86 a qt. plus shipping, i think i got 10 qts for 52 bucks! not bad!!
Old Aug 10, 2007 | 10:03 PM
AGE mechanic's Avatar
AGE mechanic
I'll bite.... Where?
Old Aug 10, 2007 | 10:38 PM
slowmans's Avatar
slowmans
k-mansparts.com
