Can anyone answer my starter problem?
Old Oct 11, 2007 | 03:37 PM
jongirouard's Avatar
jongirouard
1990 Ford F250 reoccuring symptoms.
turn key to start, no click..no nothing.
try again..turn key to start..starter relay clicks..but doesn't turn over.
turn key to start..starter relay clicks..turns over then starter stops..nothing
turn key to start..starter relay clicks..starter stays engaged and starts..
sometimes it starts right up..sometimes the above symptoms occur..I don't like guessing if it is going to start or not when key is inserted.
Can anybody tell me the procedure to troubleshoot this problem?
thank you for your input.
jon
Old Oct 11, 2007 | 03:57 PM
bilder12's Avatar
bilder12
when you turn the key to ON, does it show on the guages that there is power ?
is the main problem the fact that the starter does not engage when you turn the key to crank or is the problem no power ?
if it is the problem with no cranking of the starter, you could start looking at the switch on the bottom of the steering column . My truck had a problem and it was that switch. There is also a rod coming down from the key to this switch that gets goofy and wont let the starter switch work properly. You could also be having a problem with wiring to the starter or the starter itself. Start easy and cheap.
there's my nickel.
Old Oct 11, 2007 | 07:07 PM
tjc transport's Avatar
tjc transport
i ain't rite
the starter circuit uses the switch on the column to engage the starter relay on the fender, to engage the starter solenoid on the starter.
your problem could be either
A: bad positive battery cables.
B: bad grounds.
C: bad starter relay.
D: bad solenoid.
E: bad wire connection at the starter solenoid.
my guess is E
Old Oct 12, 2007 | 07:26 AM
jongirouard
there's my nickel.
thanks bilder great advice.
will look into this..
jon
Old Oct 12, 2007 | 07:28 AM
jongirouard
B: bad grounds.
D: bad solenoid.
my guess is E
thanks tjc
this gives me something to start with.
thanks for advice, i will go get started.
jon
Old Oct 12, 2007 | 07:30 AM
jongirouard
does anybody know of a webpage that would show me the electical diagram for starter circuit..
you know like from key to rod.. to switch.. all the way to starter..
thanks for your help
jon
Old Oct 12, 2007 | 07:36 AM
PLC7.3's Avatar
PLC7.3
Pm me an email addy or click on my name and email me and I will send ASAP. Ask for: 90 starter schematic
Old Oct 12, 2007 | 07:19 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Look at the battery cable on both sides of the passenger side positive battery terminal.
If the cable insulation looks like it has been hot, or if the diameter of the cable where it enters the terminal is larger than it is a couple inches away I would suspect the positive battery cable.
You could also remove both negative cables and then take a resistance reading on the cable on both sides of the clamp.
After you get the first reading, wiggle the cable around while taking a second reading on both sides of the clamp.
More than once I have seen corrosion inside the terminal where it can not be seen.
I went through this several years ago on my 86.
Started at my house like a champ.
Drove a little less than a mile to a friends house, acted like a dead battery and just clicked.
Finally got it started using jumper cables.
When I got home I took a cut off wheel to the clamp and cut it open.
It was so bad, I don't see how it had started at all for a long time.
Old Oct 15, 2007 | 07:58 PM
jongirouard
thanks plc
i sent you an email
appreciate your help.
jon
Old Oct 15, 2007 | 08:00 PM
jongirouard
dave ..thanks for the help..
i will look asap for signs of cable problems..
yall are a lot of help.
jon
abranz
Nov 16, 2014 01:07 AM
OldWoodsDiesel
Jul 23, 2013 01:37 PM
1486LP
Apr 29, 2013 06:30 AM
patmorrison
13
Feb 27, 2004 03:20 PM
kluelessjo
Bronco II
Aug 30, 2003 06:50 PM
