Help with starting problem
Old Nov 13, 2014 | 09:51 PM
abranz's Avatar
abranz
Since the temps have dropped to about 10 F our EX has developed a starting problem. Turn the key to run and the dash lights up, chime runs and everything seems ok but when I turn the key to start nothing happens. Starter doesn't click, try to turn, nothing. After about 5-8 cycles of turning the key the starter will finally start the engine with normal speed. Battery is one yr old. Battery terminals are clean and tight. Would this be a symptom of a ignition switch failing? Thanks Anthony.
Old Nov 14, 2014 | 03:42 AM
Twitchyleprechaun's Avatar
Twitchyleprechaun
I have the same issue. I have tried to track it down and have came up empty. The ignition is the only other thing I can think of.
Old Nov 14, 2014 | 09:21 AM
abranz's Avatar
abranz
I'll work on it and let you know what I come up with.
Old Nov 15, 2014 | 02:42 AM
abranz's Avatar
abranz
It was the starter. It would hang up even when bench testing it.
Old Nov 15, 2014 | 05:37 AM
Twitchyleprechaun
My starter, alternator, and both batteries have been replaced within the last year. I will take thebstator off though and test it out. Thanks.
Old Nov 16, 2014 | 01:07 AM
abranz's Avatar
abranz
The starter was a reman viseon brand. The bendix would even hang up up on the bench. Bought a new one and it started fine for the past 2 days in 0-10 degree weather. Thank goodness.
LRSTony
1997 - 2003 F150
Jun 11, 2015 03:40 PM
neaners
Apr 15, 2015 10:01 AM
ju015dd
Nov 17, 2010 07:55 PM
taandctran
16
Jun 2, 2010 10:05 AM
oarhead61
Apr 12, 2006 02:13 PM
