1989 Bronco II won't start
Hey everybody, I'm new to the forum, but it seems like a very nice site. Anyway, I was run into head-on by a hummer a couple of months ago, and little problems keep creeping up.
(I'm running a 1989 Bronco II XL, 2.9L 5-speed manual, 4x4).
About a week ago, after stalling the engine, I turned the key. I heard a click from the general area of the starter relay, and my entire electrical system immediately went dead, and not a peep from my starter. I tried the key a couple more times, nothing happened, I banged my head on the steering wheel for a minute, then I tried again and the engine turned over.
The next morning, the engine turned over just fine, but I heard that starter relay click again, a noise I had never noticed before and which didn't occur again until yesterday. Again yesterday, when I turned the key the whole electrical system went out (radio, lights, even the voltage gauge disconnected which normally reads when the car is off). As I turned the key a few more times, I only heard that clicking noise about 10% of the time. The engine won't turn over at all, so I disconnected the battery's negative terminal. My battery voltage is steady at 12.5 V. I haven't had a chance to load test it, though. Any thoughts, suggestions for diagnosis? Replacing the relay is a priority for me (if I can get to a parts store!), but the combination of symptoms doesn't really make sense to me.
Sounds like your battery is weak & do for a replacement. Before doing that clean the battery terminals. If no start turn on the ignition with the car in neutral, block the wheels & than jumper across the solenoid with a heavy wire. Jumper from where the + lead connects to the other side. If no start you have dead battery or possible a bad starter. If start you have weak solenoid.
DattMavis
09-15-2015 12:04 PM
Singing River Farm
18
01-25-2014 03:51 PM
w74bronco
01-22-2014 07:59 PM
