sd oil pump
Old Oct 5, 2007 | 09:54 PM
lazerf250's Avatar
lazerf250
Question sd oil pump
i am going to be getting stage 2's and need a sd oil pump is there a certain year that only works or will any superduty do just fine. Also is this a bolt on or do you have to make some stuff up?
Old Oct 5, 2007 | 10:29 PM
wreckit72's Avatar
wreckit72
You will need a HPOP off of a 1999 to 2003 7.3L. Here is good write up on doing the swap. https://www.ford-trucks.com/forums/5...stall+write+up
Old Oct 5, 2007 | 11:01 PM
powerstroked162's Avatar
powerstroked162
Make sure you get a good reman if your buyin from furd. I have gone through two reman 17* pumps so far. Good luck
Cowboy Steve
Old Oct 5, 2007 | 11:33 PM
lukecline's Avatar
lukecline
What has failed?
Old Oct 5, 2007 | 11:55 PM
97REDPSD's Avatar
97REDPSD
Is there any way you can make your 15*into a 17* oil pump ???
Old Oct 6, 2007 | 12:06 AM
powerstroked162
Originally Posted by lukecline
What has failed?
Dunno, im not the HPOP expert. Just know what they do and somewhat of how they do it.
Cowboy Steve
Old Oct 6, 2007 | 12:18 AM
rtxcoon's Avatar
rtxcoon
Lazer, didnt you just ask about this a few weeks ago?
https://www.ford-trucks.com/forums/647829-sd-hpop.html
Last edited by rtxcoon; Oct 6, 2007 at 12:31 AM. Reason: added the name lazer, so cowgirl stephanie would know who I was talking too
Old Oct 6, 2007 | 12:21 AM
powerstroked162
Nope, sure didnt. Thanks for the rep points by the way I was sure to send some your way
Cowboy Steve
Old Oct 6, 2007 | 12:23 AM
DIESELSITE's Avatar
DIESELSITE
Former Vendor
Yes, you can swap swash plates from the 17 into the 15, however, you have to be able to get into the pump to begin with and you have to have a 17 degree plate from a late 99 pump......and if you had a late 99 pump, you'd probably just install THAT pump.
Unless you were building a PULSE..........
Special note: If you're using a late model pump, make sure you get a pump for a 99.5. The Early 99's still had 15 degree pump.
Bob
Old Oct 6, 2007 | 12:29 AM
rtxcoon's Avatar
rtxcoon
Cowboy Steve
if you would have looked at the link, you would know I was talking to lazer...
dont get so caught up in yerself there cowgirl...
dont ruin another thread with your bull **** ok...
leave this one alone...
ok buddy?
Old Oct 6, 2007 | 12:57 PM
tjbeggs's Avatar
tjbeggs
As said the pump for a 99-03 should be a 17*. For your 97 it is a direct bolt in. For 94.5 to 95's its not but it will work if you do a standpipe mod which I guess I don't have the link for on this computer.
Old Oct 6, 2007 | 04:17 PM
barebackjake's Avatar
barebackjake
bob whens the pulse coming out??????????????????????????????????????????????
Old Oct 6, 2007 | 05:26 PM
DIESELSITE's Avatar
DIESELSITE
Former Vendor
I am still working on it if you can believe that I appreciate you asking... don't stop.
Hopefully soon, I may be able to just post that we're good to go.
Bob
Old Oct 6, 2007 | 06:07 PM
barebackjake
ive had a twinpump that i had on my performance motor i just havent messed with getting it in this motor, it was a twin i built years ago but hadnt got all the bugs worked out. i like the single pump idea ive always wondered about using the same tech as the factory pump just supersizing componets?? ive got a buddy thats a custom machinist but hes beyond he eyeballs in projects he has had the same thoughts on it. or a twin swash plate in a single housing, too bad alot of the hydraulic pumps cant handle the heat, higher pressures, and lower viscosity oil
JMM-MD
Mar 3, 2013 06:04 AM
rodneywar
Jul 2, 2012 07:19 PM
strokersace
Jan 14, 2010 10:00 AM
captchas
Aug 10, 2005 12:26 PM
