OD button not working
Old Oct 3, 2007 | 04:40 PM
Fard's Avatar
Fard
I just noticed my OD button isn't working, no light just dead, the van is running as if in OD. Seems like it's maybe just disconnected or maybe something else? Sorry if this belongs in tranny thread, thought i'd try here first. Tranny is otherwise in excellent shape, shifts well and smooth. THX
Old Oct 3, 2007 | 07:17 PM
jroehl's Avatar
jroehl
Year, engine and tranny specifics usually help, but I'll take a stab at this anyway. As far as I know, all the fords with OD buttons (electronically-controlled trannies), the button is for turning overdrive OFF. Default is for OD to be ON. So, my guess is that either the button/switch is bad, or the LED/bulb is bad, since you think you still have OD.
Jason
Old Oct 4, 2007 | 02:59 PM
rclarke's Avatar
rclarke
The circuit to the OD switch on the shifter is fused in the interior fuse box, check that first.
Old Oct 6, 2007 | 06:15 AM
kynnhoj's Avatar
kynnhoj
The wires that come out of the shift lever are very fine and fragile. They exit the lever at the base and typically break just as they exit. You have to buy the whole lever and switch as one unit. If you remove the steering wheel cover, you'll see the wires. Good luck, John
Old Oct 6, 2007 | 02:49 PM
rclarke's Avatar
rclarke
Actually the switch is replaceable. But you are right the wires that come out of the lever are fragile and often rub on something on the column. If the insulation on the wire wears through it often will short out on something metal in the column and blow the fuse. Replacing the lever is the only proper repair for shorted wires. In an emergency I have put a little tape on the wires to get by for a short while. But the wires must be very flexable and tape will stiffen the wire.
Old Oct 6, 2007 | 03:41 PM
Fard's Avatar
Fard
How does that button assembly come off? if i need to repalce the switch. Actually I am assuming the fuse is blown, so maybe if it works don't fix it, will be my choice of action, or non-action. I never drive with OD off anyway, just wondered if there was something up with the tranny is all. THX
Old Oct 7, 2007 | 02:22 AM
paetersen's Avatar
paetersen
A thin pick or fine flathead screw driver will allow you to pry under the end cap. Once that is removed you can slide the switch and light cover assembly out.
On a related note, has anyone had success replacing the LED in the switch? Mine no longer lights up but the switch still works fine. I am not buying a whole new switch for a $0.03 LED. Stupid fords...
paetersen
Old Oct 7, 2007 | 07:26 PM
mhg's Avatar
mhg
go to the you pull it yard and snag a good one there
just about the easiest part to pull yourself
Old Oct 8, 2007 | 09:04 AM
Fard's Avatar
Fard
I popped it off it looked liked somebody had tack glued it on or something cause three of the little prongs were already off, then it slides right out. I haven't checked the fude yet, but if it's fried, then I am gonna glue it back in and forget about it, i never used it on my F-150 anyway.
jasonodsky
Nov 28, 2010 08:29 PM
CPUNeck
Mar 9, 2010 01:12 PM
mxhowes1
Mar 1, 2008 03:49 PM
bandlgeorge
May 29, 2007 05:04 PM
mrpopo
Jul 2, 2003 06:10 PM
