'97 E4OD overdrive button quit working
Old Mar 1, 2008 | 03:29 PM
mxhowes1's Avatar
mxhowes1
'97 E150 van 110K 4.6 E4OD
This van hads the overdrive button on the end of the shifter. My son is on a trip and told me that the OD light doesn't come on and it doesn't down shift when he pushes the button. It's always worked before. It seems to shift in & out of OD OK when you step on the gas, it's just the manual override button isn't working. Is this a common problem? and easy solution I can give him over the phone. Just trying to save the brakes on some of the downhills.
Thanks,
Jim
Old Mar 1, 2008 | 03:49 PM
mike93's Avatar
mike93
Check the OD fuse (#20) in fuse panel for the dash. Over time the wire running up the tilt stearing column will break over time from use of the tilt mechinism. this may need repair.
Sooner Fan 66
Jan 4, 2014 07:00 PM
WILLYSFREAK
34
Dec 20, 2011 01:28 AM
boulderguy
Nov 6, 2011 08:27 PM
david1993
Apr 20, 2011 07:54 PM
PCola
Apr 6, 2004 10:18 PM
