No power when engine is wet
Old Oct 3, 2007 | 04:35 PM
cchildress's Avatar
cchildress
Ok I like to keep my truck spotless and the engine! Every time I wash the engine tho water gets in to some electrical connection and when I go to crank it up it loses idel and throtle I can floor it and it will climb a lil and then just fall on its face!!! Today it would only run with the check engine light on and if I turned it off then it would die a few times b4 the light came on and then it would run. I had to drive it around for about 30mins so it could dry out and now its fine. Iv put that dy electric grease on most of the connections but Im lost and I hate it!!!
Old Oct 3, 2007 | 05:29 PM
tjbeggs's Avatar
tjbeggs
I would get the PCm scanned for codes. that will point you in the right direction as to which sensor it is. I too like to keep my engine clean but I have never experienced that problem.
Actually now that I think about your description I think the EBPV (exhaust backpressure valve) is closing on you. I had that happen the first time I used the pressure washer. To test it unplug the two wire connector that is bolted to the intake side of the turbo right under where the intake tubing goes to the turbo.
Old Oct 3, 2007 | 06:39 PM
c00nhunterjoe's Avatar
c00nhunterjoe
check for a chaffed wire on the main harness that goes across the left valve cover
Old Oct 3, 2007 | 06:42 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
You can find here the location:
http://rides.webshots.com/photo/1030...0211cZOLspiYVv
Old Oct 3, 2007 | 06:44 PM
Action4478's Avatar
Action4478
No disrespect to Tim or Joe,, if it sets a hard light , I would suspect the ICP sensor,,,,JMHO.....
See if the light is a 1211.....
Old Oct 3, 2007 | 06:45 PM
Action4478's Avatar
Action4478
I' also wondering about IDM....
Old Oct 3, 2007 | 06:46 PM
Action4478's Avatar
Action4478
As Tim said , get it scanned....
Old Oct 3, 2007 | 06:47 PM
SrqScion's Avatar
SrqScion
First time i cleaned my engine I got water in the ICP and fried it somehow. Unplug the icp and see if it clears the problem up next time it acts up
-eric
Old Oct 3, 2007 | 09:26 PM
cchildress's Avatar
cchildress
Can I scan it with my superchip 1705 or do I need to go to a dealership?
Old Oct 3, 2007 | 09:30 PM
wreckit72's Avatar
wreckit72
Yes you can scan it with your Superchips programmer. Check back in with the codes.
Old Oct 8, 2007 | 02:33 PM
cchildress's Avatar
cchildress
Hey I just ran it for codes and it threw P1212 and P1211.
Old Oct 8, 2007 | 03:52 PM
glasseater's Avatar
glasseater
then that's ICP sensor and...???
Old Oct 8, 2007 | 04:46 PM
Cuda_jim's Avatar
Cuda_jim
Unplug the ICP and blow the water out of the connector. Next time don't get it wet........said the master of the obvious
P1211* ICP Not Controllable — Pressure Above/Below Desired
P1212* ICP Voltage Not at Expected Level
*Check Engine light illuminates when fault is present. On California and all Econoline, CHECK ENGINE light will turn off if no fault is detected for four consecutive drive cycles
Old Oct 8, 2007 | 04:47 PM
Action4478's Avatar
Action4478
Some info here....
X7 KOER ON-DEMAND DIAGNOSTIC TROUBLE CODE (DTC) P1211
  • DTC P1211 indicates that injection control pressure was above or below commanded desired pressure during self test mode.
  • Possible causes:
    • incorrect oil or viscosity
    • poor oil quality
    • gel fuel/no fuel
    • low fuel pressure
    • damaged IPR valve
    • high-pressure oil system leak
    • damaged high-pressure oil pump
    • damaged PCM
  • Verify correct oil quality/viscosity and correct fuel grade are being used for the temperature conditions.
& a bit more here...
Z14 CONTINUOUS DIAGNOSTIC TROUBLE CODE (DTC) P1212
Dry clean the motor.....
D-RockJD
1978 - 1996 Big Bronco
Nov 6, 2012 10:56 PM
craigm126
Electrical Systems/Wiring
Nov 12, 2011 07:33 AM
DISLFVR
Sep 28, 2011 10:00 PM
HT32BSX115
13
Jan 3, 2008 01:38 PM
jjlrrw
1997 - 2003 F150
Aug 15, 2006 08:42 PM
