Dp just ordered
Old Oct 1, 2007 | 07:45 AM
tcm368's Avatar
tcm368
now im new to Diesels this is my first. But what exactly does it do and is this location under that Plastic Powerstroke plate
Old Oct 1, 2007 | 07:51 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Originally Posted by Vader0121
Does the 120 setting put out enough smoke to make he happy and keep the wife quiet?
After seeing me smoke some ricers for stupid driving with satisfactory results, now when my wife sees someone display a less than gracious driving manuever she gets a wicked grin on her face and looks my way and says "INK EM"!!
Old Oct 1, 2007 | 07:57 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Go to dp-tuner.com it should explain everything!!
Old Oct 1, 2007 | 08:06 AM
tcm368's Avatar
tcm368
i have ordered the Overboost kit as well but i feel like im going to need to purchase a Boost gauge in order to set that properly, is this so? and should i even run the chip without the kit or is it something that i can wait on installing till i purchase gauges
Old Oct 1, 2007 | 08:42 AM
ron's power stroke's Avatar
ron's power stroke
a boost gauge is good..you should also have a pyro,and trans temp gauge as well...over boost kit is a good idea but not needed if you drive light footed..when the map sensor see 23 to 25 PSI of boost it will set the ses light and defuel the truck...the over boost kit keeps the map sensor from seeing any thing above 22
Old Oct 1, 2007 | 08:51 AM
tcm368's Avatar
tcm368
Ok im going to look into the gauges. the only thing tho if i install the kit i would have to set it with a gauge, correct? or if anyone coulde maybe tell me how many rotations they used on a simular truck with the same basic mods.
Old Oct 1, 2007 | 12:25 PM
ron's power stroke
did you get this one ??
http://www.itpdiesel.com/store.php?c...on=show_detail
most of them are all set to where it needs to be..the one i listed is all set where it needs to be when you get it..its just adjustable for other trucks..so dont adjust it..
Old Oct 1, 2007 | 12:28 PM
tcm368's Avatar
tcm368
yeah i got that kit but i went direct and ordered right from Dp-tuner web site. so im hoping that it should be set
Old Oct 1, 2007 | 01:22 PM
Izzy351's Avatar
Izzy351
It will be -- that's where I got mine from. I can still set the low HPOP pressure code on 80 when I stand on it. Don't worry about it though, plenty of power in both settings...
Joe
Old Oct 3, 2007 | 02:22 PM
tcm368's Avatar
tcm368
great cant wait for it to be delivered
01PS
15
Feb 19, 2012 04:28 PM
LFDavidson
Paint & Bodywork
Oct 11, 2010 11:46 PM
03_PSD
17
Nov 2, 2007 09:45 PM
powerstrokinsmokin
15
Oct 3, 2007 07:39 PM
foxracer800
Mar 10, 2007 10:26 PM
