Does anyone have a rough measurement height and width for the inner firewall cover for 48-50 F1's; I am going to use metal and will be looking today for piece to cover.
Yeah, tonight would be fine; I have access to sheet metal at work that I have already cut to make glove box. It will end up being roughly :
9 3/4" W x 10" D x 6" H . I will be polished. Will post pics if it turns out.
I would cover the firewall metal with vinyl on the inner and sound deadening on the firewall side.
Tom, I got hole alot later than I thought so I did not get a chance top post the information lastnight.....thats life in the oil patch. The dimensions are shown on the drawing below. Hope this helps.
I hear you on the oil patch; I get home next week after 14 days.
Thanks for the dimensions; I am going to use light gauge aluminum, roughly 24 - 26 ga which is fairly pliable. I am using same material for glove box and plan to bend that up later today.
I'll post pic if everything looks good.
Oops....looks like I forgot to change one of the copied measurements the overall dimension is 45 1/2 x 19 1/2 inches. I will replace the drawing in my gallery with the correct dimensions.
I am re-thinking the material for the firewall cover, the aluminum is light weight but will dent. Like Ross' idea for more pliable/cost effective material; there is a PVC upholstery material I think.
I did fab the glove box, posted final product in my gallery under cab mods. Delaying install of same until I finish wiring interior.
My office moved and now I am almost next door to a pond liner supplier, I keep meaning to stop in but haven't made it. Will try again Monday!
Bobby and I went to a swap meet about a month ago and I picked up some carpet real cheap. It is hard to describe, but has almost no nap, yet feels soft. It is supposedly replacement for modern cars' carpet. Has an integral layer of stiff foam. It is more rigid than pond liner, but only 3/16" thick, might lay better. I bought it for my headliner but had thoughts of using it on the firewall. Unfortunately it isn't black, it's grey, and on the firewall it might be too bright.
I pondered using the original cover as a template and "coating" it with some sort of resin (fibreglass or other) ; fibreglass would be too brittle, I think. Can you think of any other products that would have more flex ?
Sounds like a whole lot of hard work, I really like the one I bought from Hot Rods Classic Truck Parts, Black ASB already insulated and fits perfectly..
Tom
I'd be flat amazed if you could get the old one out in one piece. Mine is corrugated cardboard, is yours? Mine is totally brittle from heat and age, and appears to be glued in place with a tarry substance (like body seam sealant).
I heard about some stuff used by upholsterers called Sintra ABS. It is available in sheets and apparently can be molded somewhat with a heat gun. If your interior is gutted, you could probably get a single piece in there and heat and mold it. Might be worth checking, but I think you'd want to cover it with some kind of material.
