Coolants
Old Sep 27, 2007 | 10:47 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Joe and Kris, what do yall think of this method of draining, courtesy Pop a couple of years ago:
Crawl under your truck and look for the oil filter. To the rear of the aluminum filter adapter there are two plugs on the side of the block. The one closest to the adapter and closest to the pan rail is the crankcase inspection plug. That's not the one you want.
Now, a couple of inches farther up and back, there is another plug. It has a 1/4" square recess (on mine). Don't take it out until it's time to get wet! ;-)))
There's a corresponding one on the other side of the block which is a little harder to get to, but possible. It will look the same.
Let it drain then refill w/clean water and run till therm opens up. Drain it all out again, and fill w/new 50/50. Is this method overkill or is there an easier way?
Hopefully 8 gals will refill her completely.
Old Sep 27, 2007 | 01:48 PM
Izzy351's Avatar
Izzy351
That's what I was talking about -- that still leaves a little in the block, and a little more in the heater core. That said, if you fill with 50/50 after that, it'll be okay. I've heard of many others doing just that. Yes, it's a little under 50/50, but it's okay unless you're in the Arctic.
Joe
Old Sep 27, 2007 | 03:41 PM
homesteader's Avatar
homesteader
Is the Rotella ELC the same as the Cat ELC?
Old Sep 27, 2007 | 03:47 PM
Izzy351's Avatar
Izzy351
That I don't know... I seem to remember it being different stuff (is it like purple or something??).
Joe
Old Sep 28, 2007 | 01:17 PM
homesteader
Quick question. I got 02 450 was a little low when I bought the truck.I added about a gallon of the green stuff .I found out that it wasn't good until I got on to FTE by then it was to late.I plan on flushing just waiting for housing,203 stat and red coolaid.Question is how long can I run the truck with the green stuff in it. THANKS
Old Sep 28, 2007 | 01:42 PM
Izzy351's Avatar
Izzy351
Technically, for the normal life of the green. Once you pour in the green, you use the same maintenance schedule as if you had all green. Since you're already switching to red, I'd hold out and get the coolant filter as well. After that, you shouldn't have to mess with the system for 300k (as long as the water pump holds). With the filter, the water pump life is extended quite a bit...
Joe
Old Sep 28, 2007 | 03:57 PM
homesteader
IZZY would mixing cause the coolant to gel?Iam not sure if the guy I bought it from was just adding water .I notice a small leak coming from the bottom right plastic dowel that goes through the bottom mount.So I must get that fix to.THANKS
Sparx Macgyver
S. California Chapter
15
Aug 18, 2010 01:03 AM
mj6gte
Apr 26, 2010 07:30 PM
KiotiLee
Jul 12, 2008 01:25 AM
DISLFVR
Apr 6, 2007 11:00 PM
cfrives3
19
Feb 1, 2007 10:20 PM
