Coolants
Old Sep 26, 2007 | 09:47 AM
Izzy351's Avatar
Izzy351
Coolants
Just want to clear something up -- there were a couple threads recently about coolants and flushing. The one that just popped up made me think fo this...
I think I referred to the Rotella ELC equivalent at Wally-World as "Peak Global Lifetime". That is **INCORRECT**!! The red ELC there is "Final Charge" with the pic of the big rig on it. They're right next to each other, so be careful. There is a difference, and I hope I didn't steer someone wrong.
Just wanted to post that, because I realized when I was at WM yesterday that I screwed up, and that thread made me remember that I wanted to post a correction. I'll see if I can find the other thread and post a correction there as well...
Joe
Old Sep 26, 2007 | 10:02 AM
DieselCamper01's Avatar
DieselCamper01
Izzy, Thanks for the follow through and thoughtfulness to make a correction. I had just read the other post a minute ago. Rep points given.
Old Sep 26, 2007 | 05:55 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Good, i wanted to change over to the red coolant, so it's at Walmart huh? Is it concentrate, because thats what i want. Almost everything ive done under the hood is red and red water in the bottle would look tit.
Old Sep 26, 2007 | 07:28 PM
Izzy351's Avatar
Izzy351
LMAO... AFAIK, it's only in the 50/50 mix. ~$10/gal.
Old Sep 26, 2007 | 07:32 PM
Izzy351's Avatar
Izzy351
BTW, here's their website:
http://www.finalcharge.com/
It was the "Global" part that got me... "Peak Global Lifetime" and "Final Charge Global" were apparently too much for my feeble brain synapses to keep separate...
Joe
Old Sep 26, 2007 | 08:37 PM
F350mikey's Avatar
F350mikey
Good looking out. I am going to flush my coolant this weekend, what is the difference between the Rotella ELC and the "Final Charge" coolant?
Old Sep 26, 2007 | 09:27 PM
Izzy351's Avatar
Izzy351
Nothing -- same stuff. I'll be putting it in mine next.
Old Sep 26, 2007 | 09:40 PM
PowerstrokeJunkie
So how does one go about getting all "water" out of the system to add in pure 8 gallons of the 50/50 mix?
Old Sep 26, 2007 | 09:44 PM
Izzy351's Avatar
Izzy351
I'll make it even easier... Looks like this:
Joe
Old Sep 26, 2007 | 10:09 PM
F350mikey's Avatar
F350mikey
Awsome,thanks Izzy.
Old Sep 26, 2007 | 10:43 PM
Bird Dog's Avatar
Bird Dog
Awsome,thanks Izzy.
Looks like three different types there. Is there a difference in them. One looks like 50/50, what are the other two? I'm doing my flush in two weeks. Thanks for all the info!
How do ya like the job change?
Old Sep 27, 2007 | 02:38 AM
homesteader's Avatar
homesteader
Hey IZZY thanks for the info doing my coolant change soon .So you are saying you could mix the Rotella ELC with the Final Charge Coolant and it will be OK? How can I test to see if the mix is good .Heard some people talking about some kind of stick to check the mix if so where can I get them .Thanks
Old Sep 27, 2007 | 07:17 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
New avitar Izzy!! Can you hear me now? Good.
Thanks for the info I need to change mine this weekend.
Old Sep 27, 2007 | 09:34 AM
Izzy351's Avatar
Izzy351
I wouldn't mix it homesteader. Get about 20 gals of distilled and run it through the system and it should be clean enough to add the red stuff.
There are three -- one is the concentrate, one is the 50/50 and the third is for swapping from standard coolant to FCG. It's a method for companies with large fleets so every single truck doesn't have to be completely flushed & refilled. For us, I think it's best to just do a flush with distilled & refill with the standard FCG coolant. You only need 8 gallons of 50/50, or 4 gallons of concentrate with 4 gallons of distilled water...
Here is the link to the converter product if you want to read about it yourselves:
http://www.finalcharge.com/converter.html
BTW, it almost sounds like I'm pushing this stuff as an owner or something. Not sure how I ended up as the "expert" -- just trying to straighten out my own screw up!! You can use this, Rotella ELC, or whatever you want -- I'm not in the biz nor do I have any interest in the company...
Joe
Old Sep 27, 2007 | 09:37 AM
Izzy351's Avatar
Izzy351
Don't know, Kris. You might try compressed air to blow out the heater core *carefully*, but for the stuff left in the block, I don't know. I'd be interested to know how much coolant & water the system takes after being "completely" drained. I've heard of folks using the 50/50 stuff without any problems, but I'm OCD/**** retentive enough to want it at the right mixture...
Joe
