Nebraska Chapter Join Chapter, Leader: 97nukeford
Project Update!!!!
Old Nov 22, 2010 | 09:27 PM
  #301
jseim44's Avatar
jseim44
How does everyone lift cabs off the frame? I'm interested to know what works and what doesn't work. I am getting ready to make the '72 a '71 and vice versa.
-Jake
Old Nov 23, 2010 | 08:15 AM
  #302
67nukeford's Avatar
67nukeford
Veteran: Navy
I had my brother in law, and his tractor help me Jake. This is a pic of the bed coming off, but the cab worked the same way. Otherwise, if you have about six guys, you can set some saw horses on the sides of the cab. Have four guys lift it up, then have the other two runs some 4x4's underneath the cab on to the saw horses. Set the cab on the sawhorses, then roll the frame from out under it.
Old Nov 23, 2010 | 02:19 PM
  #303
gquinn8516's Avatar
gquinn8516
I'd tell ya Jake but I am afraid you might try it and I don't want you to put yourself in the same kind of danger I did!!! My wife just kept calling me a hillbilly and wouldn't watch. It did involve rafters and ratcheting straps though!
Old Nov 23, 2010 | 02:27 PM
  #304
67nukeford's Avatar
67nukeford
Veteran: Navy
Using rafters......damn hillbilly..........LOL!
Old Nov 23, 2010 | 10:04 PM
  #305
imabaka's Avatar
imabaka
Rafters? Lol I used a couple chains and a hoist.
Old Nov 28, 2010 | 12:07 PM
  #306
jseim44's Avatar
jseim44
I got it handled. I made some MAJOR progress. I have a ton of pictures that I will post up after I get done and have time to get them loaded. And I had the best way for lifting everything off.....you guys will be so jealous!!!
-Jake
Old Nov 28, 2010 | 07:29 PM
  #307
gquinn8516's Avatar
gquinn8516
Did it include ratcheting straps and rafters?
Old Nov 29, 2010 | 09:18 AM
  #308
67nukeford's Avatar
67nukeford
Veteran: Navy
Well, quite making excuses, and post up some pics Jake!
Old Nov 29, 2010 | 09:25 PM
  #309
jseim44's Avatar
jseim44
72 Ford pictures by jseim44 - Photobucket
For all you people that wanted to see. We'll see if anyone figures out how I lifted the body off. I can guarantee you it was WAY easier than George or Pat did it!!!
And I bet no one has seen a Camper Special highboy
I had to switch the harnesses for the alternator/voltage regulator because the one on the motor was missing a plug in for the power to the cab. Got that switched but it won't crank, and I just realized (literally as I'm typing this) that I'll probably have to bypass the neutral safety switch since the cab came from an auto. Anyway, put the hood on, make it run, put the clutch pedal and linkage in and I'm good to go! I would've gotten it all done but I had to do brakes on my girlfriend's car and I wasn't exactly up at the crack of dawn everyday......
-Jake
Old Dec 11, 2010 | 05:33 PM
  #310
jseim44's Avatar
jseim44
Got the Highboy all done. Might still have a ground issue on the tail lights and I need to hook up my tach and mechanical oil pressure and temp gauges. She is all ready to go. Took it for a drive and I still need to get the timing dialed in but it IS driveable!
On to the next project....
-Jake
Old Jan 8, 2011 | 12:57 PM
  #311
jseim44's Avatar
jseim44
Finally got my gauges all hooked up this morning. Got all my lights fixed a while ago. Now I am fighting a pesky oil leak from the drain plug. I just can't get it stopped. Oh well, I'll figure it out sooner or later. Then it will be time to add power steering and after that I will be "done" with it for awhile.
It's somewhat of a sad day.....we are going to kick Ol Blue out of the heated shop today and put her in storage for the winter. I hope she understands......
-Jake
Old Jan 8, 2011 | 02:18 PM
  #312
big-ugly's Avatar
big-ugly
-Jake
So how exactly did you lift the body off?.. you never said.
Old Jan 9, 2011 | 10:27 AM
  #313
jseim44's Avatar
jseim44
No, I didn't. You are correct. This is what I used.....http://i292.photobucket.com/albums/m...ture064.jpg:-D
Took some current pictures yesterday before I put Blue away for hibernation.
http://i292.photobucket.com/albums/m...Picture002.jpg
http://i292.photobucket.com/albums/m...Picture001.jpg
-Jake
Old Jan 26, 2011 | 10:55 PM
  #314
jseim44's Avatar
jseim44
Got some air bags to put on the GMC so maybe when I pull a trailer or haul something I can air them up and it won't squat so bad. It wasn't too bad until I put the leveling kit on it and now when I put something in it that would normally level it out it squats and I just can't stand it. So I'll throw those on this weekend. Maybe go get the '71 from my brother's and see if I can fix the oil leak it has.
-Jake
Old Jan 28, 2011 | 11:08 AM
  #315
big-ugly's Avatar
big-ugly
For some reason I wasn't subscribed to this thread anymore.. I never got to see how you did it, and now your pictures "have been moved or deleted". Care to post again? I am curious now.
