Sponsored by: Real Truck
In bed lighting
Old Sep 24, 2007 | 10:05 AM
merlins'92f250d's Avatar
merlins'92f250d
In bed lighting
I am looking at installing some type of lighting in the bed so I can see the 5th wheel hitch at night. Anybody else do something like that? I am looking for something that will be out of the way so as to not be easily broken.
If anyone else has done something like this I would sure like to see and hear about what you did and how you like it.
Thanks to all!
Old Sep 24, 2007 | 10:52 AM
Lonewolftx's Avatar
Lonewolftx
Wink Try these . . .
I installed the Recon truck bed lights. They are LED clusters that have 6 LEDs per cluster. There are 4 clusters to each side of the bed and install up under each bed rail. I wired mine to the 3rd upfitter switch so they can be switched on but only when the key is in the on position. Here is the link.
http://www.gosocom.com/products.php?...2FCargo+Lights
Old Sep 24, 2007 | 11:34 AM
merlins'92f250d
Lonewolf, do those lights from Recon give off a lot of light? Are you happy with them at night? They look like just what I am looking for but dont want to spend $100 on them if they are not going to do anything except glow
Old Sep 24, 2007 | 11:40 AM
Lonewolftx's Avatar
Lonewolftx
Wink Not Bad . . .
No, they light up very well and give of a soft bright light. Mounting them was a pain for me as I had my truck bed sprayed and the 3m tape didn't stick very well. You can see there are little screw hooks on each cluster which I had to use.
Recon was very helpful and even when one of the clusters went bad they sent me a new string to replace it. They are a sponser and have excellant customer service. This is the best application for light in the truck bed I have found yet.
Old Sep 24, 2007 | 11:54 AM
merlins'92f250d
Cool! I think this is the route I will go! Thanks for the help and advice
Old Sep 24, 2007 | 12:10 PM
Lonewolftx's Avatar
Lonewolftx
Wink
NP, hit me w/ some rep point my man . . .
Old Sep 24, 2007 | 12:19 PM
blackhat620's Avatar
blackhat620
merlins'92f250d,
Here is another option for in bed lights, see Bear Hunter's post #128
http://www.ford-trucks.com/forums/59...th-pics-9.html
Old Sep 24, 2007 | 12:24 PM
IndyDog's Avatar
IndyDog
Nice...looks like a good mod for the short days coming up
Old Sep 24, 2007 | 01:26 PM
Lonewolftx's Avatar
Lonewolftx
Wink
Originally Posted by blackhat620
merlins'92f250d,
www.ford-trucks.com/forums/597703-stealth-reverse-lights-mounted-with-pics-9.html
Blackhat, he isn't talking about backup lights, he is looking for in the truck bed lighting.
Old Sep 24, 2007 | 01:32 PM
DCSpecial's Avatar
DCSpecial
Post #128 is about in bed lights.....I like Kevin's setup (Bear Hunter), cheap too.
Justin Jones
Aug 12, 2014 09:10 AM
fishmanndotcom
Jan 13, 2012 08:39 PM
Jmudder79
Paint & Bodywork
Jan 7, 2008 04:14 AM
026TB4U
Aftermarket Products
Oct 22, 2004 10:19 AM
