Installing a Pyrometer
I have been doing a lot of reading on installing a pyrometer for the same reason as most to turn up the IP, but at this point im not even sure if im going to do that after i replace the injectors and adjust the FIPL NEXT weekend (damn you 1-5 business day shipping ). Anyways, as i said, ill be installing one, and i feel iffy as far as confidence goes, so far I have learned you need to drill into the exhaust manifold seems like either side is fine, but my question is can any ol drill and bit get the job done? What are the chances of me cracking it? Should i drill straight down into the exhaust manifold? Or up through? or from the side?
Then, while i was reading about how to i came across this quote "just used a drill bit drilled a hole tapped it and hooked every thing up not to hard, i put mine in the third cylinder back on the driver side exaust manifold, thats as far as i could get back with my drill but its right on top of the cylinder"
My question with that is by him saying tapped it, does that mean he used a tool to create threads so im guessing the pyrometer can be screwed in there?
And by the way how does the pyrometer "fit" into the said drilled hole?
Also do i have to drill into cab to run the line back up to the gauge or are there pre-designed places i can come through? If i do have to drill through where would be the best place?
thanks guys i know this is probably a lot less complicated than i'm making it out to be but drilling into the exhaust manifold seems a little scary haha. Thank you for any and all help.
what he said^^^^.
just when you tap the drilled hole. don't go to far or the pyro probe will never tighten down. tap a few thread and test fit the probe. go slow like that and you will be good.
i have not drilled mine yet, but i have heard that the mani's are soft and drill easy. some like to use some grease on the drill bit, some don't. if you are turbo'ed then i would take the crossover pipe of and vacuum out the manifold after you get everything done. you don't want those chips going threw the turbo. if you are not turbo'ed then don't worry about that.
have a read here.... it explains drilling and tapping for the pyro and where to put it.
Auto Meter
some more info....
3-Gauge Install Pictures
Auto Meter
some more info....
I am actually the one he was talking about first time on here in months lol but after having my pyro in the place that it's at I'm not sure it's the best place I get a really fast acurate reading but I think it's actually in the flash area (think that's what the area is called where flames come out exhaust) anyway I without a turned up ip can easily hit 1400 and have 1 time only did it while not paying attention on my way to work (yesterday actually) accidentally pegged out the pyro and it reads up to 2000 I was fighting 45mph winds coming directly towards me and climbing up a slight grade and I wasn't even getting into it so I'm not sure it's the best location for it anyway I just bought a standard drill bit from my local tsc and it had to be the specific size for the thread tap and I didn't have any issues
Amazon.com: Sunpro CP7019 Sport ST 2" Electrical Exhaust Gas/Pyrometer Gauge Kit: Automotive
Bahhh I guess ill get what i paid for but i figured for $88.00 ill take a chance on this seems like if its all there and works that its a helluva good deal. Otherwise, ima be pissed .
what he said^^^^.
I did mine from below, right by the last bank on the drivers side. Easy to get at. Remember to wear safety glasses, metal chips (and rust flakes) in the eye are not fun.
I can't remember where I put the wires through. I want to say I was planning on drilling a hole, but either stuffed it through with the something else, or the spot where the speedo cable goes through was rusted out large enough.
Depending on the setup, you might need ignition power for the gauge itself, and separate wiring for the light. Pyro's aren't mechanical, they're all electrical. Basically there are two metals in the probe and as they are heated, they generate a small voltage differential. The gauge shows this minute change in voltage. Some brands incorporate a booster box that requires power to run, while others require no other input (like mechanical gauges.
Also, you can't just extend the probe wires. They need to be made of the same metal as the thermocouple inside the probe, otherwise it will screw up the reading. Extensions can be purchased if needed, but have to be matched to the type of probe (most likely Type K ).
DON"T cut the leads for the pyro either. it WILL screw up the readings.
The use of grease is so the chips stick to the drill bit (and tap). This is particularly important for people with turbos. Turbos don't like to ingest metal chips. For N/A trucks, the chips aren't an issue as they go right out the tailpipe. Due to the composition of cast iron, it doesn't require oil when drilling or tapping, the grease suggestion is just to trap the chips.
