390 PushRod length?
Old Feb 12, 2019 | 11:45 PM
66_Galaxie390's Avatar
66_Galaxie390
So Dutch?? How did the length of the pushrod work for ya? I’m kinda in the same boat. Do you have anymore info of the push rods? Is there a tolerance we can get away with??
Old Feb 14, 2019 | 04:01 PM
PROSTOCK's Avatar
PROSTOCK
We used to deal with this all the time. I'm going to guess what the OP had could have GM pushrods. When building race engines you run into this quite a bit and as long as the rod type is the same (diameter and ball socket configuration) the engine sure doesn't care. I've got Buick rods in my Clevor.
Old Feb 18, 2019 | 11:57 PM
mark a.'s Avatar
mark a.
Comp Cams or most any Cam mfgr for that matter will make them any length you need and get them right out to you.
Old Mar 10, 2019 | 12:32 PM
675261's Avatar
675261
Bad Lifters?
Originally Posted by Destroked 450
Check the lifters, compare them to the originals, FE lifters have a shorter pushrod cup height than other Ford lifters, they are all the same diameter but the taller height of non FE lifters won't allow the valves to fully close.
We also go a set of lifters once that would pump up and not bleed down causing low compression issues, that problem drove us nuts for a while until we figured out what was going on.
I think I have a similar issue. Compression is about 90 psi across the board (wet and dry). I replaced the heads and still have a compression issue. Seems like if I let the lifters bleed down a few minutes, the compression comes up. I just ordered some new lifters (Howards) and am going to try replacing them... Thanks for the post. It's been hard to find much info on this.
Mrhorsepower6472
Nov 8, 2021 11:54 PM
the_hetz
Jan 13, 2017 01:37 PM
Neo64
13
Oct 1, 2016 06:03 PM
chiefsfootball
Jun 29, 2016 04:21 PM
luc719
May 14, 2016 10:54 AM
